It is currently Wed Jun 24, 2026 9:42 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 78 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Tue May 27, 2008 2:00 pm
tumwatertaz wrote:
I personally always install all 30 amp fuses
Isn't that a bad thing? You want to make sure your wiring can handle that much current, or else your wires will get hot, and you run a risk of fire. Even on top of that, if you have a wire that is too thin and you push too much current through it, you'll lose voltage to resistance. Some things you woulnd't notice that much of a difference, but for things like lights, they will get darker the lower voltage.
I nearly always use 12 gague. I think most of the stock wiring in the LUV is 16 gague, so I would reccomend keeping in 15A fuses, unless you have added some of your own circuits. If they are blowing, then you have either overloaded a circuit, or you have a short somewhere.
This chart is about car stereos, but it's the same information when it comes to anything car electronic.
Remember, Amps = Watts/Volts. (or Volts * Amps = Watts). So if you have 4x 100Watt off-roading lights, that convets to 33.3 Amps. So as long as my ligts can use 16ft of wire or less, I can put them behind 10gague wire for best performance.
-1979 LUV 4x4
PostPosted: Tue May 27, 2008 3:54 pm
I am keeping 15A fuses. The bigger stuff is for those higher amp alternators and high performance components. I just want the Point A to Point B thing, not the showy flashy stuff. I like it all, don't misunderstand me, but I don't need to spend more money just to wow the crowd.
If I put higher amp fuses in the truck the way it is now, I might ruin a component that those 15A fuses are designed to protect. I also have the braided ground strap on the block. Then the fuse off the battery is a 25A blade type, not a fusible link.
All I know is it runs smooth and seems to want to run whenever I get ready. That's all I need. Can you go faster than me? I'm not worried about racing. I just don't want to ride the bus anymore. I haven't rode the bus for over a year now.
'78 1.8L 4-speed Fleetside
Image Image
PostPosted: Tue May 27, 2008 8:57 pm
Use relays for higher current loads. Check this out.
http://www.offroaders.com/info/tech-corner/reading/automotive-wiring.htm
PostPosted: Tue May 27, 2008 11:23 pm
PITA Old Fart
I've rewired just about everything under the hood because it was really a mess when I got it and used heavier guage wiring and I'm running a 50 amp alternator so it's not likely to cause a problem. Plus when I replaced my bed, I replaced all of my wiring under there with heavier guage too.
I hate electrical gremlins and I know darn well that on any vehicle this old, the wiring is going to be all FUBAR'ed from it's previous owners and old age, so that is SOP with me on any old vehicle I restore or fix up.
:roll: You're kidding, right?
PostPosted: Wed May 28, 2008 8:43 am
No, I'm not kidding. I know your LUV has a bigger engine and a bigger carb, as well as all the good work you did on it. I congratulate you Tazzy, but it's not my cup of tea, or maybe I should say, energy drink. I'm satisfied with the power I have and I don't need all the further enhancements. I want to redo the exhaust and get my truck all painted. I don't know when that'll be. Anyway, this thread should have answered a few of the questions for a lot of people, and that's all I wanted. Thanks to LUVTruck.com for this great website. Thank you Catman and Tazman for all the comments, as well as Uthe, 800xl, Rondog, and PapaG. There's several other threads where this same subject was covered and Nukeday was around. Here's a shout out to EricQ and DBest, as well as to Ben. There's more out there, but I got things to do today, and I can't spend three hours naming everybody.
The thing is, if you pull up alongside me at a light, and we're in front with nobody in the way, I'll give you a mean look and rev my engine to high heaven then when the light turns green I'll smile and wave as you disappear into the horizon. Then when the cop pulls you over for reckless driving and speeding, I'll wave again as he's writing you a nice ticket and then I'll disappear into the horizon!!! Drive safe.
Image Image
PostPosted: Wed May 28, 2008 11:24 am
Haha! that reminds me of the time I went to the cruise strip and revved my stock engine next to a corvette :lol: Little did he know our race was "see who can go the slowest!" and I won! He shot right on past me!
-1979 LUV 4x4
PostPosted: Wed May 28, 2008 11:33 am
Sorry to start off-topic discussion, but Taz, did you use a kit to do this, or did you get spindles of wire to do it with? I have a bunch of added electronics and circuits alongside with the stock wiring (I have a 100Amp internally-regulated alternator, Power Inverter, Stereo & Subs, And off-roading lights, soon going to add an electrical fan to replace the mechanical fan). It was all done with either 8 gague or 12 gague wiring. I've also added handfulls of mechical relays all over the place. I'm trying to decide if I want to replace all the stock wiring with new stuff, but I'm afraid that will be very expensive, as well as very time consuming.
-1979 LUV 4x4
PostPosted: Wed May 28, 2008 3:30 pm
PITA Old Fart
I have a rack filled with spools of heavy guage wire in 8 different colors, and I just rolled out whatever I needed, grabbed my wire strippers, my soldering gun, my wire cutters, some shrink wrap, several roles of electrical tape, and attacked my wiring when I got my truck all stripped down to just the cab and the frame. This wasn't my first time at bat with an old vehicle, and I've learned the hard way about old buggered-up worn out wiring harness gremlins.
It may be a bit time consuming and tedious to do it all by hand, but I guess you just have to ask yourself:
"Why is there never enough time to do it right the first time - but always enough time to tear it all apart later and re-do it?"
And me personally, if I want flames around my truck, I prefer that they are fake ones that are painted on...lol
And fulla, I don't street race in town in traffic, (that's how innocent people get killed) so that stuff doesn't work on me. But I have embarassed the hell outta a few fart-can Hondas and other dumbass looking ricers that were trying to crowd me as I was getting on to the freeway...lol They just get this real dumb look on their face when I grab a lower gear, when they hear the secondaries kick in, and they listen to my exhaust roar while watching my tail lights pull away from them...lol
I've had my glory days at the track, and paid enough tickets when I was younger - so now I just try to behave. (In a Tijuana cab driver kinda way...of course.)
PostPosted: Wed May 28, 2008 5:59 pm
I had a wiring harness that was complete from under the hood and under the dash. I sold it for $50 to a guy who drove his LUV through some high water on a road and wanted to rewire with an original harness. I knew the harness was worth more than that, but the guy had to gall to try to talk me down even lower. Making a wiring harness wouldn't be hard, just time-consuming, and I would if I needed to. I sold the harness because I know I'd make one if I needed it.
And I've already had a few experiences like you mentioned, Tazzy. The Weber is so cool!! I hate it when people make a turn in behind me then change lanes almost immediately because they think I'm not going to pedal fast enough! Then they find out I'm outrunning them! Ha ha. Yep the Weber is the one for the LUV. The 32/36 gets better fuel economy than the 38/38, and that's important to me.
And I'm glad you're driving safe and sane on our streets Tazzy. That means you'll be around longer to keep bugging the hell out of me. But I'd have a beer with you anytime if there came an opportunity to.
Thanks for the link PapaG. That's for adding things on, and I like to do that. I added fog lights in the front bumper, but I don't know that I did it the "right" way. I just know they work. I think a roll bar would be nice, with some Hella lights. I also thought about adding two Baja seats to the bed, with seat belts, so my son can ride in the back with a friend.
And this thread is anything anybody wants it to be. I'm done talking about the Weber. Unless of course, someone has a question or another comment.
Image Image
PostPosted: Wed May 28, 2008 11:23 pm
The Rollbar/off-roading lights are my favorite part about my LUV, even though I can't use them on public roads (although, I do plenty of country driving late at night, but with the lights on, you can't even tell it's night time!)
Now for the secret, I built my roll bar out of a bed frame and a crappy welder! I was doing a service project for some place and I spotted it in the dumpster. My buddy pointed out how it was a little too long for my bed, but he said he had a welder and we could make it work.
It is funny the looks we get from people. They'll make a comment about my roll bar, then I'll tell them it was built out of an old bed frame. Then they laugh and say it does resemble one.
All my pictures are on my computer in kansas, or else I'd post some good ones of the roll bar.
One thing to keep in mind though, is you will need a bigger alternator than stock if you plan to use the lights. I have 100Amp alt that can sustain 14 volts on idle, however, when I turn on the lights, my voltage drops to 12 on idle (I can still push 14 if I'm moving though). I believe that stock alternator is 35-45 Amps depending on wether you have AC or not. I have 4x100Watt lights, which equates to 33 amps, or 1/3 of my 100A alternator's capacity.
-1979 LUV 4x4
PostPosted: Thu May 29, 2008 6:39 am
Well then it may just be something on my wish list for a long time to add any more to the LUV. Good advice from you guys. I'll just leave mine the way it is for now, and try to keep gasoline in the tank.
Another thing I want to change is that horn. It sounds like a kitten mewing. Matter of fact, when I'm on the move, I can't hear it. I always watch people to see if they look my way...that's how I know the horn worked. I saw one on JCWhitney for around $15-$16. I'd kinda like to add the Oogah horn. They make them electric now. Does anybody know if they work well or not? Other suggestions?
Image Image
PostPosted: Thu May 29, 2008 11:08 am
I wanted to get a train horn off ebay and mount it to my roll-bar, but who knows if I'll ever actually do it. They're not cheap.
-1979 LUV 4x4
PostPosted: Thu May 29, 2008 6:00 pm
LOL Scenario: Coming to a train track, Uthe, (after installing his train horn), blows his horn to tell somebody to get moving faster. Unfortunately, the driver of the car in front thinks the train is coming and stops on a dime. Better watch out Uthe! A train horn would make people stop in a panic. Ha ha. Or maybe if you got behind one of those cars with a bumper sticker that read: "In Case of Rapture this Car will Become Unmanned", then the driver might open the window and holler, "What about me?!! :smt043
Image Image
PostPosted: Fri May 30, 2008 11:33 pm
whats all this talk of oil catch cans with bigger cams. Ive never needed one. Also as a side note the under side of my hood and entire freakin engine bay will never rust... :lol:
PostPosted: Sat May 31, 2008 3:37 am
PITA Old Fart
Lmao!
PostPosted: Sat May 31, 2008 9:52 am
Cams are really interesting. That's camshaft spelled correctly. The one Catman referred to earlier is a modified cam, I think. It wouldn't be any larger than a stock cam, but the lobes have been re-ground to open/close the valves earlier/later. The result is enhanced performance. It's a good thing. I know we all want our LUVs to do exactly what we tell them to do, and it is in us all that when something isn't right with our ride we want it fixed. Some of us don't take that step to better performance and thus never know the joy and ectasy of the better ride. I don't know what everyone on LT.com has for a LUV, (or a UTE), but I know a few of us. Regardless, it should be well-established here that the LUV truck, the chassis and the engine, are a do-it-yourselfer's dream, and a right sturdy one. Modifications done correctly to the truck yield great results, and that is largely the reason we're all here. For the love of a LUV.
I've got a new stock cam here in the box that I got off ebay. You know the pin in the cam? The one that goes in to the timing chain sprocket? Mine slipped out a couple times and into the sprocket. The engine stops immediately. The first time, I put the pin back while the camshaft was still installed in the engine. When that failed very shortly, I removed the camshaft and used a vise to hold it while I replaced the pin in tight. It's still working just fine. I didn't install my new cam. I talked with the machine shop awhile back and they advised me there was a concern with the mating surfaces between the camshaft lobes and the rocker arms. One used surface would not mate correctly with a new surface. Meaning that if the new cam was going to be installed it should be milled/prepped for the existing rocker arms, so that they will mate surfaces, and not cause premature failure. The machine shop, (Pacific Auto in Renton, right off Hwy. 405 and Maple Valley exit), advised me that ignoring this preparation would precipitate failure at an astonishing rate. I also acquired a special lubricant that should be applied to the lobes when this procedure has been followed, which would aid the mating of the surfaces. I don't know when I will put the new cam in, but getting the modifications done to the camshaft is an intriguing thought. We're talking about thousandths of an inch here, opening and closing of the intake and exhaust valves at varying degrees of rotation. Yes, I know it makes your head spin. If you have the mathematical skills maybe you could explain it, but the end result is enhanced performance. I know I've said I like to get from A to B, but it's even better to arrive safe and happy when the ride was fun. May we all do so.
Image Image
PostPosted: Sat May 31, 2008 6:47 pm
PITA Old Fart
J/K...lol
A cam can be custom-designed By Delta Cams to match whatever you want it to accomplish for your engine. There are a lot of variables involved in choosing exactly what lift and what duration will work for your needs. I'll just leave that to them - they are the experts. So if you wanna know about Cams, I'd highly recommend you giving them a call (use their toll-free number if necessary), and talk to them. They are nice folks and I'm sure they will have no problem answering any/all questions you might have.
As for puting a new cam in a used head - you should have a manual around handy so that you can make sure that your head, rocker arm assembly, etc. is still in decent enough shape to install the cam into it. I personally always check the spec's, inspect everything for allowable tolerances, and visually inspect everything else before I install a new cam. Also, I always use plenty of good quality cam assembly/installation lube, and re-adjust my valve clearances before I start my engine up. Then I turn my idle up high and let the truck run for about 20 minutes or so to break in the cam. Then after a few days of light driving, I check my valve clearances again, adjust them again if necessary, and change my oil and filter.
As for the pin that aligns the cam with the gear - I've seen first hand what happens when the pin snaps or comes out and the cam stops spinning while the engine is still running, and it aint pretty. Unless of course you really enjoy looking at holes in piston tops, and all-bent-to-hell valves....lol
So obviously you want the pin in there snugly, and you want to make damn sure you tighten the gear down on the end of the cam to the proper torque specs. The manual explains that all in detail, and the guys at Delta Cam will install a freh pin in your new cam and make sure it is in their snug. So if you get a cam done by them, I personally wouldn't worry too much about it.
So far, I've never had one fail or had any other problems with one yet. And Idoubt if lasthas much to dowith that. If I was lucky, would I have been born this ugly and poor?
PostPosted: Sat May 31, 2008 9:32 pm
PITA Old Fart
LMAO!
You and me in the same bar drinking together fulla is probably not a very good idea...lol But thanks anyway.
See what happens when you are trying to type and talk to the wife at the same time? That should say:
" And I doubt if luck has much to do with that."
Sorry for the double post but my edit time ran out before I spotted that. Any staff member can feel free to copy/paste that in and then delete this.
PostPosted: Sun Jun 01, 2008 8:32 am
I was reading about swapping the tranny and rear end off an Isuzu Pup for the beneficial qualities, and that's some good stuff. That would be fun to do, and I might explore the possibility for myself doing that. Bar? Who said anything about a bar? I'd rather be outdoors with lots of space and open air.
Anyway, I just thank all the guys who have helped me with parts and advice, and may LuvTruck.com last forever.
Image Image
PostPosted: Tue Jun 03, 2008 10:02 am
I would just like to thank all who contribute their experience gained wisdom to this site. My 79 LUV croaked about a hundred miles from home a few weeks ago. After trying all the usual fuel related stuff, I sprung for the Weber 32/36, rather than buy a new vehicle. What a difference! (The *Hitachi was running rough, anyway.)
I did have a problem with the Weber running out of gas until I opened the fuel pressure regulator to 3.5 psi. I had started out at 2.0 psi.
I can see a problem plugging the fuel return if the gas cap is sealed/pressurized, so for now mine is open. I intend to put a small breather-type filter on the end to keep the crud out, but let the air flow in, to prevent creating a vacuum in the gas tank.
I do have one problem to try to figure out. After going up a hill at full throttle (in a LUV, is there any other way?) something is sticking wide open for a short period when I reach the top and release the gas pedal.
Now if I could just get my wife to let me do an engine rebuild and electronic dizzy, I would have a (relatively) hot running machine.
Thanks again for all your input.
Users browsing this forum: Majestic-12 [Bot] and 27 guests
