It is currently Fri Mar 27, 2026 5:37 pm
 Post subject: Spring Bushings
PostPosted: Sun Jun 15, 2003 9:43 pm
where cna I get a set of rear leaf sprign rubber bushings for an 80 4x4 LUV.......jc whitney?
PostPosted: Wed Jun 18, 2003 8:05 am
anyone?
PostPosted: Wed Jun 18, 2003 8:56 am
check out autozone man. i almost bought a set off of them but it would've took a week to get em so i sauid screw it.
PostPosted: Thu Jun 19, 2003 3:00 pm
check autozone, they said they are not avalible. I'll try advanced and napa tommorrow
PostPosted: Thu Jun 19, 2003 6:04 pm
damn that sucks. call around a little bit. i'm sure you could find them, their just bushings. does s'10's have rear leaf springs? they may work. trooper?? let me know where you what you find out. i'm gonna need a set.
4x4. check out my new system in my car on cardomain :D
PostPosted: Thu Jun 19, 2003 6:07 pm
hey ben if you see this check out all our posts count. it's all the same numbers :?
PostPosted: Tue Jun 24, 2003 9:54 am
They are similar o a Nissan not a S-10. The shackle is part of the thru bolt. I had some made from aluminum. They are a little more than 1.250 OD with about a 5/8 or 11/16 thru hole. I had one at my desk, but my ruler is not in metric.
PostPosted: Tue Jun 24, 2003 11:48 pm
the schucks that i get stuff through is ordering neoprene spring bushings for my luv.
PostPosted: Thu Jun 26, 2003 10:23 am
Did you Check Summit Racing?
1981 Chevy LUV 4x4 2.2L Diesel 4 Speed Selling out moving over to VW TDIs.
