It is currently Sun Feb 22, 2026 2:05 am
 Post subject: big tires :D
PostPosted: Wed Mar 19, 2008 3:27 pm
how big of tires can i use with about a 2inch body lift. and what are the limits on the trans and engine ? are 33s to big for stock engine and trans except for header and weber what do u think?
 Post subject: Re: big tires :D
PostPosted: Wed Mar 19, 2008 3:40 pm
REGEAR! 31's without cutting, 33's with cutting...
31s will be a little harder to push, 33s will definitely give you grief and heartache... the limits on the trans and enginge depends on your right foot, common sense and what gears you have in the diffs :D
PostPosted: Wed Mar 19, 2008 4:04 pm
do u know of a place i can find lower gearing that will fit in the luv diffs?
PostPosted: Wed Mar 19, 2008 4:39 pm
Hey, I put 29.5's on mine with a 3" body lift and I had to still cut about a half inch at the bottom rear corner of the front end. I didn't do any offset tho.
PostPosted: Wed Mar 19, 2008 5:58 pm
I have 31's with a 3" body lift, had to chop off a chunk of the rear part of the front fender. It has the stock 1.8 with a Weber 34 and does ok so long as you arent in a hurry to get off the line. I am also thinking about re-gearing, I cant help but feel the clutch is a little overworked getting the whole mess rolling from a standstill.
PostPosted: Sun Apr 20, 2008 9:19 pm
I have 29" super swampers on mine with a 2" lift and it just misses the fenders.
Powered By LUV
PostPosted: Wed Oct 08, 2008 9:48 am
post resurrector
Shoot you can go with that body lift and crank the the tb's and get about 2-3''s of lift and easily fit 33''-12-50.
'80 luv 4wd 6.0 vortec hurst 4spd process of lifting
'69 f-100 4wd 14" lift and 44s
'03 f-150 4dr 4wd daily
BOOMER SOONER!!!
Users browsing this forum: No registered users and 0 guests
