It is currently Sun Feb 01, 2026 8:46 am
PostPosted: Sat Apr 12, 2008 4:39 pm
yesterday I set my timing with a light after setting it by ear and melting my timing light clip on the header. So I set the timing back to 6* initial and went for a drive. The truck wants to hold first gear for ever after taking off from a stop. I figure this has to be something caused by vacuum. Why or what is causing this problem?
PostPosted: Thu Apr 17, 2008 7:05 pm
if its like my th 350 i have a vacuum line that runs from the back of the intake to the trans look and see if you might have moved or bumpted it and broke an old hose
I will no longer do that thing with my tongue
PostPosted: Fri Apr 18, 2008 9:18 am
I looked at the vac line and it checked out. I ended up pulling the side cover off and lubricating the pivot points on the govenor and it took care of the problem.
