It is currently Sun Dec 21, 2025 10:29 am
Post new topic Reply to topic  [ 24 posts ]  Go to page 1, 2  Next
 Post subject: coil over mounts
PostPosted: Thu Jun 12, 2003 8:34 am
Any of you fellas that converted the front to coil overs ever thought about fabricating mounts to sell? Would save others time and make you some money. Just a thought I had. If I had my own welder Id be doing it.
PostPosted: Fri Jun 13, 2003 4:59 am
I can burn you some out and send them with the payment for the lenses if you would like.....if I had pictures I would send them, but I don't yet.
03Cobra
PostPosted: Fri Jun 13, 2003 8:35 am
Resident Sparktrician
I would like to have some of these mounts too. Then, I could get my truck up in the air for 33's to go under. :twisted:
Kuranosuke
Grampa's Driving:
1990 Luv 4X4 "Family Cab"
got BOOBIES? 8O 8)
PostPosted: Sat Jun 14, 2003 5:50 am
one note about coil overs if you are wanting to go up.....the space inside the A-arm decreases when the angle gets greater........
to get the coil over in there I had to jack the A-arm up.
sooooo.......that might not be the route you want to go..... :(
03Cobra
PostPosted: Sat Jun 14, 2003 8:18 am
I come from a long line of hackers. I meen engineers. Alittle "clearancing" will do the trick. :lol:
PostPosted: Sat Jun 14, 2003 8:58 am
That's cool, thanks for the info. The need of a solid axle in the front is becoming more and more apparent. I was hoping it wouldn't come to that, but...
Kuranosuke
Grampa's Driving:
got BOOBIES? 8O 8)
PostPosted: Mon May 23, 2005 7:41 pm
could you stil make some of the mounts? im going to be needing some
PostPosted: Tue May 24, 2005 5:40 am
I can not still make the mounts, however I do have the drawing for them. If you find a fabrication shop with a plasma table, or water jet table that will cut them out for you, I will send you a file they can work with.
03Cobra
PostPosted: Sat May 28, 2005 3:02 pm
http://www.somuscle.com/luv/scan0009.jpg
Big Bore, Short Stroke!!
Click my WWW to see my pics
PostPosted: Sun May 29, 2005 11:13 am
ten2ndLUV wrote:
cant really see the pic, maybe a newer brighter picture??
PostPosted: Sun May 29, 2005 1:21 pm
were you still able to lower your truck on to the bump-stops if you wanted to?
PostPosted: Mon May 30, 2005 1:48 am
PostPosted: Tue May 31, 2005 5:39 am
yep
good pix!
03Cobra
PostPosted: Sat Jun 04, 2005 3:03 pm
Kuranosuke on your name dealy under your post.......what do u mean by "family cab" ?
PostPosted: Mon Jun 06, 2005 11:18 pm
Hey,Luv4me just wanted to say thanks again for the coil over brackets you sent me in 2004.The brackets you sent me are by far the way to go.(Makes a tough job easy and clean)Truck runs 10.10 front wheels up 12" and 1.35-1.38 60ft times. Totally street legal.If I only knew how to put a picture on here.
PostPosted: Mon Jun 06, 2005 11:35 pm
Swap Specialist Mod
you can email me the pic and ill host it for you.
neil
PostPosted: Mon Jun 06, 2005 11:41 pm
Sounds great. I have the disc in my hand.Might have to wake the wife
PostPosted: Mon Jun 06, 2005 11:44 pm
Swap Specialist Mod
mkay. send it to farmerjoe620@gmail.com
neil
PostPosted: Mon Jun 06, 2005 11:56 pm
Did you get my e-mail
PostPosted: Mon Jun 06, 2005 11:58 pm
Swap Specialist Mod
yeah. is yours the grey one on that website?
neil
