It is currently Sat Jun 27, 2026 6:42 pm
PostPosted: Sat Sep 07, 2002 9:29 pm
Does anybody know if i can use isuzu pup front disc brakes on my 74? I dont know the year pup its the one of the lasts bigger rounder body style here is the vin: JAABL14L3G0732280. whats everybody using for brakes on their trucks? thanks.
PostPosted: Sat Sep 07, 2002 9:49 pm
Refer to the information section at the start of the site , it has a disc brake section that explains this. Bryan
 Post subject: pup disc brakes
PostPosted: Sat Sep 07, 2002 11:05 pm
I already read the article on the disc brake swap but i wanted confirmation that any chevrolet luv OR isuzu pup no matter what body style with disc brakes will bolt right up to a luv with drum brakes as long as its not a 4X4. are their any other disc brake options anybody knows about?
PostPosted: Sun Sep 08, 2002 11:35 am
OG Lifer
is yours a two or four wheel drive? if it is a four wheel, see if you can find the front end off of a newer luv for more reasons than just the brakes. you will also find more parts for a newer front end. mine is a 79 and i can still get all the parts i need to re-seal it or new bearings. just a suggestion
WATCH YOUR PIEHOLE!!!!!!
 Post subject: disc brakes
PostPosted: Sun Sep 08, 2002 2:48 pm
My luv is a 4X2 and i want the best brakes i could find for it. S i guess i'll take the brakes off the pup. does anybody have any other suggestions for brakes?
 Post subject: i bought
PostPosted: Mon Sep 09, 2002 1:28 pm
i bought remanufactured wheel cyls from carquest and im sure they will have any of the other hardware for them- they have had everything i needed for my luv except for heater hose- which no one had!
Brent
 Post subject: brakes
PostPosted: Mon Sep 09, 2002 10:32 pm
Can anybody give me a yes or no answer if the 81 pup brakes will bolt on to a 74 luv? and any other info on good braking.
