It is currently Sat Jun 27, 2026 10:47 pm
 Post subject: transmission
PostPosted: Fri Apr 11, 2008 6:00 pm
well I blew up the trans in my elky need suggestions on companies that build them.
I am looking at b&m, tci, and mikes transmissions in ca I guess they do some good work from what I have heard so far. some of the nmca guys run mikes.
I was considering the tci street fighter or the super strret fighter
B&m not to sure about I haven`t heard anything about them
art carr builds some awesome ones just out of my price range from what I have seen they start at 2800.00
hughes is a local company here I have had problems and so have some of my friends. one guy lost a 1/2 second when he installed a hughes trans and converter. hughes said there was nothing wrong with it. He borrowed a friends tranny that was a diiferent brand and the car gained it`s time back. So i won`t even consider them.
so if you or had any experience good or bad I would like to here it.
 Post subject: Re: transmission
PostPosted: Fri Apr 11, 2008 9:55 pm
I have a Griner turbo 400 that I bought used for my drag truck. If you use a tranny brake they have the best one. A lot of tranny companies use Griner brakes in their trannys.
PostPosted: Sat Apr 12, 2008 2:34 am
TCI is local to me and they do pretty good work, I have a BTE stuff in mine and I really like their stuff, we build our own. Also heard good things about Abruzzi...
PostPosted: Sat Apr 12, 2008 3:54 pm
I have never run a trans brake but have thought about it. Can you a tranny equiped with a trans brake on the street? I really don`t know how they even work I was told they lock first and reverse together.
PostPosted: Sat Apr 12, 2008 4:25 pm
You can, but you will have to manually shift up and down each time you stop and start. The automatic shift function is no more.
PostPosted: Sat Apr 12, 2008 4:45 pm
That doesn`t bother me, It seems like all the trans brake ads are reverse pattern. Do they make them with the normal pattern. I could manage the reverse but if my wife ever drove the car{ not like that would ever happen} I could see her really screwing up.
PostPosted: Sun Apr 13, 2008 1:30 am
Glide brakes are forward pattern, all others I have seen are reverse, that I can remember...
PostPosted: Sun Apr 13, 2008 1:41 pm
Ok thanks for the info
