It is currently Mon Jun 08, 2026 11:36 am
 Post subject: more power
PostPosted: Wed Apr 02, 2008 7:04 pm
what chevy motor could i put in my 81 luv that dose not required cutting or welding.or what could i do to get more power from my piece of crap isuzu motor.
 Post subject: Re: more power
PostPosted: Wed Apr 02, 2008 7:21 pm
Hello,
First what kind of engine is it? Diesel or gas?(1.8,1.9,2.2,or 2.3). If it is gas than I can give you some advise. I made a ram air intake for my 79 luv. That helped a lot. Then I removed all the old factory exhaust pipe and scrapped it. Had a muffler shop copy the bends of the factory exhaust so it would fit,but made it out of 2" exhaust tubing. Used a flowmaster muffler. All of this combined really brought my tired 1.8 to life. After driving it for a while I removed the carb and rebuilt it. Added bigger jets and a few more mods to it. Took the truck to the 1/8 mile track and raced it. I made a 12 second pass. I thought that was pretty good for my little Isuzu engine. hope this helps.
Mike
PostPosted: Wed Apr 02, 2008 7:44 pm
it's a 1.8 gas engine. i already did the 2in exhaust. and the card reduild.but not the intake.i also took off some uneed weight.like a/c,windsheld water bottle,spare tire and bracket's,rear bumpper and bracket's.and went from glass to plexy glass side and rear window's.all together 100 and some pound's.could do more but now want to hit the motor
PostPosted: Thu Apr 03, 2008 7:55 pm
8) Well Tomluv34 you can change out the camshaft for a bigger one. I'll have to find the thread,but there is a company that custom make/grind you a high lift cam. There is a lot of potential in the Hitachi carb. Believe it or not,but I can pull a 16 ft car trailer loaded using my 4x4 luv with all the adjustments listed above in my other reply. The truck pulls everything just fine,however I'm glad the trailer has brakes. :lol: The stock brakes don't stop that well.
Correct me if I'm wrong,but your luv has the eletrical distributor/not points? I'm just tring to think of way to help you.
Mike.
PostPosted: Sat Apr 05, 2008 6:21 am
Go for a Weber, a header and a Pertronix ignition with a Flamethrower coil. Excellent power and response. Still get 24mpg consistently in town. (no freeway driving at all).
PostPosted: Sun Apr 06, 2008 1:00 am
And if you decide to go with a Weber carb and you decide you want an Offenhauser intake, let me know as I have the intakes for sale brand new from the factory.
http://www.purerockradio.net/
Users browsing this forum: Bing [Bot] and 67 guests
