It is currently Tue Jun 30, 2026 4:47 am
 Post subject: new aftermarket gauges
PostPosted: Mon Jan 14, 2008 9:28 pm
i'm doing a new gauge cluster out of diamond plate. i'm finished with the gauges and the cluster it came out better than i thought. i'm going to post some pics.when i mount them. when i'm done i'll show the diagram i used from this website and mine from the splice in. the gauges came from oreally's. new 160 speedo,fuel level,amp,oil pressure and temp very clean gauges. got all for about $140 came with everything.
PostPosted: Tue Mar 04, 2008 4:19 pm
Cool! Post some pics! I'd love to change up mine when a v8 oppertunity arrises.
PostPosted: Wed Mar 05, 2008 7:53 pm
Wonder if it looks like mine???
PostPosted: Thu Mar 06, 2008 1:54 pm
Question: On an aftermarket speedometer, how does it work?
Does it have an adapter to connect to the stock speedo cable?
Also, is it adjustable to measure the right speed?
How is the odometer set?
I always wondered.
You went there in that?!?!
PostPosted: Wed Apr 02, 2008 1:23 am
except the tach nice how did you do the lights off two hot and 1 ground? impopriviting mine next week.
