It is currently Sun Jun 28, 2026 7:32 pm
 Post subject: No fire
PostPosted: Sat Mar 22, 2008 10:37 pm
truck cranks , no fire , check between spark plugs and cap no fire , coil to cap no fire,
replaced cap , coil , magnetic plug under rotor, cap wire, spark plugs fuel filter
any ideas??????????
 Post subject: Re: No fire
PostPosted: Sat Mar 22, 2008 10:39 pm
Were the tune up parts replaced before or after you had a no fire problem? What year truck?
PostPosted: Sat Mar 22, 2008 10:52 pm
truck is 81 and it was running before the changes it stopped a couple of weeks after
PostPosted: Sat Mar 22, 2008 10:56 pm
yes the parts were replaced before the truck is 81
PostPosted: Sat Mar 22, 2008 11:15 pm
maybe one of the wires wiggled loose . like one thatthat connects to the coil. thy to disconnect the coil, and check the wires to make sure they are all doing their jobs
PostPosted: Wed Apr 02, 2008 6:42 pm
'81 and up are a bit different from the earlier models I have experience with...
Here is a link to the wiring diagram for an '81. http://www.luvtruck.com/PDF/Series11.pdf
A common problem with the older trucks is the ignition switch, do you have a remote starter switch? Another problem on the older trucks is the fuse panel, a good cleaning and wire brushing makes a lot of difference for a lot of owners....
Hope this is some help. Good Luck...
PostPosted: Tue Apr 15, 2008 9:55 am
i don't know 81's but on my '80 i had the same problem and it was a fuse blown and i messed with it for a couple of days until i found it... might be worth checking
PostPosted: Tue Apr 15, 2008 3:25 pm
Roadshow Bob...do you remember which fuse was blown?
http://bp3.blogger.com/_RApJIlqIIM4/R8d ... C-042S.JPG
PostPosted: Tue Apr 15, 2008 5:50 pm
it was a 15 amp just forward of the radio one
Users browsing this forum: No registered users and 85 guests
