It is currently Mon Jun 08, 2026 10:27 am
 Post subject: Oil Specifications
PostPosted: Sun Mar 16, 2008 10:28 am
Hi All, I've just acquired a 1981 LUV Diesel and don't have the owners
manual. Hence, I need some help on oil viscosities used in the 2.2 L
Diesel. I'm located in the SouthEast, so operating temp range will be
32 - 100 F.
Thanks
 Post subject: Re: Oil Specifications
PostPosted: Sun Mar 16, 2008 12:24 pm
use sinthetic! lots better on your motor!
PostPosted: Mon Mar 17, 2008 5:59 am
I'm sure this truck / engine is beyond synthetic! It's only good enough
to drive around the pasture. I'm needing the weight of oil, 10w-30
10-w40, SAE 30???
Thanks
PostPosted: Mon Mar 17, 2008 9:52 am
i would run delo 15-40 in it.. good oil and designed for diesels
PostPosted: Mon Mar 17, 2008 10:47 am
Swap Specialist Mod
yep. 15-40 delo 400.
PostPosted: Wed Mar 19, 2008 6:31 pm
the synthectic really doesnt work any better for cars that havent ran it from the start. so there really is no point unless you got a new engine. this coming from my cousin who is a mechanic. any truth to this i would like to know?
do you believe in LUV at first sight or does one have to drive by you again?
76' stepside mikado w/sunroof
Users browsing this forum: Google [Bot] and 24 guests
