It is currently Fri Jul 03, 2026 12:59 pm
PostPosted: Tue Jun 10, 2003 10:43 am
Has anyone made a removable trans cross member to be used with
the stock torsion bars - something that is strong enough so the
torsion bars dont twist it up. I'm thinkin about makin one, before
the 383/trans goes in. (so the trans is easy to remove)
thanks
74 Luv - 383, 224/224cam, 200-4R, Dana 44 w/373s,
smooth idle "work truck" - 11.30 @ 121.8
67 camaro - 502 street/strip (inthe10s)
PostPosted: Tue Jun 10, 2003 12:51 pm
Ive heard of a couple of people here using cross members you can get at Jegs or Summit. Leads me to beleive theyve probably converted to coil overs though.
PostPosted: Tue Jun 10, 2003 4:44 pm
http://www.luvtruck.com/pdf/crossmember.pdf
PostPosted: Tue Jun 10, 2003 8:20 pm
That was me ^^^^^^^^^
PostPosted: Tue Jun 10, 2003 9:06 pm
no it wasn`t j/k
