It is currently Fri Jun 19, 2026 5:40 am
PostPosted: Mon Mar 10, 2008 1:04 pm
exactly what it says. lets hear it
PostPosted: Mon Mar 10, 2008 1:37 pm
straight axle = :twisted:
Inferior Front Suspension = :cry:
straight axle is good for flex and strength, IFS is good for nothing...
straight axle:
-less moving parts
-cheaper to lift
-easier to maintain/adjust
IFS:
-Expensive to maintain
-good for fast offroad driving (ie. rally and desert racing)
-expensive to lift.
What do you want to know about the two?
"I'll take 'The Rapist' for $1200 Alex..."
"That's 'Therapist' Mr. Connery"
PostPosted: Mon Mar 10, 2008 1:55 pm
straight axle for sure the winner if you wanna do off roading and crawiling plus its so easy to lift :D
No luv right now =(
PostPosted: Mon Mar 10, 2008 9:53 pm
Well, IFS is good in the respect that if your right wheel is lifted, it will not affect the left wheel, when offroading (camber). I went up a pretty gnarly rock ridden hill not too long ago and my truck did REALLY well. I like the IFS...
PostPosted: Tue Mar 11, 2008 9:59 am
I feel it is worse on sidehills because it tips your body further in the direction of rolling. I have wheeled both, and i have now gone further tipped on my side and felt more comfortable on some STEEP sidehills, more-so thatn i did with the IFS, even my friend who recently SAS'd his yota. says he feels more comfortable and he is a biut more timid than me. the problem with IFS is that both sides are always puching down regardless. unlike a SFA, that allows a pivot point and a lower center of gravity
PostPosted: Tue Mar 11, 2008 12:58 pm
ok now i guess the only remaining question is what kind of straight axle would be good, once again something off of somthing so it wont cost me an arm and a leg and my manhood... :esurprised
PostPosted: Tue Mar 11, 2008 2:42 pm
toyota front end = $400 stock (best bet, same lug pattern)
Dana 30 = $150 stock (cheap, but have to do more mods)
Dana 44 = $250 stock (mass amount of aftermarket support, make sure to get the chevy 6 lug pattern)
PostPosted: Tue Mar 11, 2008 5:42 pm
Banishment Pending
another option would be to go with a FJ60/62 front end...same setup as the Toyota min axle..except it's lots beefier :twisted:
PostPosted: Thu Mar 13, 2008 12:05 pm
Boonie Buster where do you find those prices on axles
PostPosted: Thu Mar 13, 2008 1:00 pm
those are just standard prices i have found through research over the past 5 years, they are jsut average, obviously the more built the more it costs, but these are just based on finding one that someone has sitting around that came out of their truck stock, and they upgraded to something else or some other reason. But you can generally find them for those prices on a local forum or craigslist you just have to know that you are looking for. For example i, can tell you with utmost confidence, that a stock toyota front axle is around $400 complete hub to hub. I found my HP dana 30 for $75 complete stock (i have over $1000 into it now :lol: ) , I found my dana 44 with no shafts or outers for $150 with brand new gears and a spool, i jsut took my outers/axles from a 10 bolt front and put them on it.
The prices were just for getting a rough estimate of the initial cost, it will cost more, I usually figure about $1500 base price for a completed/driving/operating solid front axle swap. The price goes up from there, depending on quality of parts, etc...
PostPosted: Wed Oct 08, 2008 2:46 pm
post resurrector
I would personally put a dana 60 in the front and a 14 bolt in the back, but they are a bit pricy and hard to find. Front 600, back 450.
'80 luv 4wd 6.0 vortec hurst 4spd process of lifting
'69 f-100 4wd 14" lift and 44s
'03 f-150 4dr 4wd daily
BOOMER SOONER!!!
Users browsing this forum: Baidu [Spider] and 10 guests
