It is currently Sat Jun 13, 2026 12:42 pm
PostPosted: Fri Feb 22, 2008 4:19 am
thinkin about backhalfing my truck suggestions on how much to narrow it and what size tires you all are running , i was thinking about 6 inches on both sides what size tires do you think i could run , or would 6 inches be a waste of time , any suggestions would be appreciated , and thanks in advance :D
junkyard racing - we win with your old parts
PostPosted: Fri Feb 22, 2008 6:15 am
Not sure how much my truck has been narrowed, will have to do measure. The tire size is 33x14x15.
PostPosted: Fri Feb 22, 2008 7:31 am
this might sound gay but has anyone ever used sprint car tires , ive ran mccreary dirt tracs and they bight good
PostPosted: Fri Feb 22, 2008 7:50 am
I knew a guy who had some dirt track tires on the back of his street/strip car (a Vega I believe), he said that they weren't too bad but didn't have the traction as drag slicks.
PostPosted: Fri Feb 22, 2008 4:28 pm
I took 2 1/2 out of each side and I run 295/50-15 on a 15x10 wheel
72 luv v-8 owned since 16!
240" rear engine dragster
[color=#FF8000]
29 dodge 4 dr sedan (project)
PostPosted: Sun Feb 24, 2008 10:15 pm
Took 8" out of each side.Run some 31x16x15 et streets
PostPosted: Mon Feb 25, 2008 11:49 am
Not sure how much was taken out...but I'm running 24" wide frame and run 29X14.5 tires on a step side. They fit nice and allow the truck to sit low with good clearance all around.
PostPosted: Mon Feb 25, 2008 5:15 pm
My frame rails are narrowed 8".
PostPosted: Mon Feb 25, 2008 5:27 pm
Same for me...
PostPosted: Tue Feb 26, 2008 12:03 am
8 on each side or 4 on each side to make 8
PostPosted: Tue Feb 26, 2008 11:24 am
8" each side.
PostPosted: Wed Feb 27, 2008 9:21 pm
Mine are 4'' on each side 8'' total. I run 28-10.5 with PLENTY of room a 12.5 would fit easily.
PostPosted: Fri Feb 29, 2008 10:36 pm
Hey cj thats a good looking truck!
PostPosted: Sun Mar 02, 2008 9:02 am
Actually yesterday was a historical day for this truck. It was the first time it has moved under its own power in over 9 years. I'm on the final stages of this project (Phase 1), just need to finish wiring it and bolt on the doors and front end. I did measure the tubs and it is narrowed 8" on each side....which seems to be the max standard.
PostPosted: Sun Mar 02, 2008 9:10 am
Congradulations!!!! It always makes one feel good when the truck runs and moves under its own power.
PostPosted: Sun Mar 02, 2008 12:45 pm
Congrats....I know how you feel,my truck should be making it's first track appearence later this month!!!!
