It is currently Mon Jun 08, 2026 10:25 am
PostPosted: Wed Feb 13, 2008 7:52 pm
Even though I release the parking brake, the light in the dash won't turn off. Any suggestions on where to start tracking down this problem?
Thanx in advance
Dano
Garage is empty;
Between trucks
PostPosted: Wed Feb 13, 2008 7:58 pm
make sure the little lever that is on the park brake by the switch didn’t break, its down by the gas pedal..
this happens allot and if it broke it wont push the switch off
PostPosted: Thu Feb 14, 2008 11:08 am
I had this happen on the '79 4x4 I had. I just put a piece of electrical tape over the plunger to keep it down. It's sort of hard to miss the parking brake sticking out if you've got it pulled... :ebiggrin
As for fixing it properly if it's broken, I think you'd need to have the tab welded back on, or just replace the whole pull mechanism.
PostPosted: Thu Feb 14, 2008 11:56 pm
My tab is simply missing. So the switch is unpluged to keep the light off.
PostPosted: Tue Apr 01, 2008 4:54 pm
Does anyone have a picture of what the tab looks like so I can fab one up.
Thanx
Dano
Garage is empty;
Between trucks
