It is currently Sat Mar 21, 2026 1:08 am
PostPosted: Sat Feb 09, 2008 5:57 pm
would it be better to swap out my points distributor for an electronic and forget the ignition box or... get the ignition box with my stock distributor?
 Post subject: .
PostPosted: Sat Feb 09, 2008 6:42 pm
I have an MSD and ditched the points. Replaced with Pertronix Ignitor module in stock distributor. Would never recommend staying with points.
FIAA: Color Guard
PostPosted: Sun Feb 10, 2008 3:12 pm
so how exactly should and could i go about this an changing away from points?
PostPosted: Sun Feb 10, 2008 3:56 pm
One method is to use a Pertronix Ignitor module inside the stock distributor, another is to do a total swap to an electronic distributor. Do a search for both, there are several threads already started with plenty of info.
FIAA: Color Guard
PostPosted: Sun Feb 10, 2008 4:05 pm
thanks that should help some.
PostPosted: Sun Feb 10, 2008 4:27 pm
This did fit my 79 the part numbers are on the boxes are:
16430 - module
an
18433 - magnet ring
is this what i should order r what?
i still have points and i want the most powerful an defficent system available.
what is the difference between this and factory electroinic dizzy?
PostPosted: Mon Feb 11, 2008 8:23 pm
So what are your favorite electronic distributors?
