It is currently Mon May 25, 2026 2:24 pm
 Post subject: loose rear axle
PostPosted: Mon Jan 28, 2008 7:49 pm
i just got my truck running today and the rearend is about to fall apart can i take to 3rd member out and tighten it a.i shims r what am i to do?
i'm talking about turning the driveshaft 1/2 in
PostPosted: Sun Feb 03, 2008 6:48 pm
ok i think i may have found a answer, can i use the rear axle out of a 94' rodeo it has 4.10 and the hubs move in the same dirrection at the same time when i spin them. i found it at the yard last friday what should i pay?
p.s. it has rear disk
PostPosted: Sun Feb 03, 2008 8:16 pm
The spring pad wont be in the right spot on that diff. You cah have a go at fittin it if you want.
You will be messing with the brakes, rear discs is different to rear drums and you need a different master cyl. Have a look around this has been covered in the forum.
So has replacing the std diff. Anything up to 87 or so will work ok. Just the e brake cables etc are different. But you can pull the third memeber and swap it.
If you hunt around theres a few different ratios.
the Impulse with the 5 link rear end has the same centre in a 3.9 ratio. LSD in manual cars.
But these are not a real strong diff. OK behind a 4 cyl but anything bigger it will just break.
Bob.
PostPosted: Mon Feb 04, 2008 9:03 pm
so basically i could swap the third member, and the axel ends to disk and it will workout for me?
and why would i have to change the master cylinder, is the pressure different or the mass of fluid.
PostPosted: Tue Feb 05, 2008 8:10 am
You might be able to swap the brakes, not sure on that. Would be a lot easier to swap the diff. The disc brake diff is larger.
Pre 87 are one size and after that it is a bigger diff.
Drums and discs work differently. Different fluid amounts etc so you need the right master cylinder.
Theres no point messing with upgrading the rear brakes unless you have done something better than the standard front brakes.
Lets go right back to the start. Is your rear end noisy on the road???
Bob.
PostPosted: Tue Feb 05, 2008 9:42 pm
terriably i can hear it almost grinding. the drive shaft moves half turn before the tires turn. i really want to replace the gear assy and lim/slip would be great i found a rear for a 94 rodeo with 4.10 and disk brakes for $200
PostPosted: Wed Feb 06, 2008 8:10 am
eurbz i have a luv rear end with weld up gears (456) it came out of my 76 worked just fine, new brake pad, 2 new u-joints, 75 you can have it if you want.
PostPosted: Wed Feb 06, 2008 1:09 pm
Be careful because the axle width is wider on the Amigo and the troopers. I use the rear disc brakes off a Amigo to do my swap. But I did measure the rearend width and it was 1-2" wider that the stock luv rear. Which would not work for me.
Craig
PostPosted: Wed Feb 06, 2008 1:15 pm
he could possibly use the rear end, just have to use a different backspacing on the rim i would think?
PostPosted: Thu Feb 07, 2008 7:25 pm
i don't think it would matter if the rims stick out .5" 1" further but will the pads line up? i can move the spring pads but don't want to.
and i have 4.10 i belive (aug/1979 4x4)
PostPosted: Fri Feb 08, 2008 6:54 am
1-2" on each side!!! for the Amigo depending on the year of the Isuzu. The trooper was even wide than that.
Craig
 Post subject: Re: loose rear axle
PostPosted: Sun Feb 10, 2008 3:18 pm
(bump) i don't care to terriable much about width just need a rear axle that won't spew forth gears when i need it most. and limited slip would be totally rightious with disk brakes to go with the trooper disk swap i hope to afford soon.
PostPosted: Mon Feb 11, 2008 5:12 pm
You need to use the Amigo rear if you want the disc setup. The Trooper rear calipers are bigger and will require alot more brake pressure / fluid. This might cause you problems with the stock master from the Luv. Use the Amigo because the rearend is not as wide and the calipers are smaller. The Amigo has Disc from the factory. You will have to weld pads on either rearend.
PostPosted: Mon Feb 11, 2008 8:49 pm
that helps so much but what year ranges? and is it more narrow that stock luv?
PostPosted: Tue Feb 12, 2008 5:37 am
The Amigo is not as narrow as the Luv @ 54" but if your not worried about the width being off 1"-2" then start looking for a 1994 up. The (3) that they had in the yard by me was 1993,1994,1996 I would go with the 1994 model with the v6 because it had the disc. The 1993 did not have the disc setup on the rear?
Craig
PostPosted: Tue Feb 12, 2008 6:18 am
You cant just put any width axle in.
It will upset the vehicle dynamics if you drastically change the track. If you make it wider you will make it understeer worse.
But then americans in general have never been to worried about going around corners or stopping in a hurry. :wink:
Bob.
PostPosted: Tue Feb 12, 2008 7:03 am
Beacuse we have concrete to stop us! :lol:
PostPosted: Tue Feb 12, 2008 7:29 pm
i agree on the concrete part but do you really think it will change the effect that much? i mean a few inch's wider overall?
i'm not sure but i wouldn't think it to drastic.
PostPosted: Tue Feb 12, 2008 9:30 pm
I don't think youl have any problems.
Craig
Users browsing this forum: Bing [Bot] and 19 guests
