It is currently Tue May 26, 2026 12:01 am
 Post subject: rotors
PostPosted: Mon Jan 28, 2008 4:43 pm
I found a guy with a machine shop here that has a great rep for work. He said he can drill my rotors but needs to see the originals. So you can only go 5 on 4 1/2 right. Any ford or chevy pattern.
Wished I had an old rotor to take him so I don't have to pull mine.
He just wants to see if the holes will work.
PostPosted: Tue Jan 29, 2008 3:57 am
The 5 x 4.5 works a little better. Here is a pic of how they will look.
PostPosted: Tue Jan 29, 2008 6:34 am
So you thnk these are really strong enough with being drilled so close to the other holes and metal being taken out. I suppose you evidently think so if you are running them.
Will see what happens. Gotta come up with an old rotor to take him before I drop mine.
PostPosted: Tue Jan 29, 2008 2:02 pm
They aren't drilled in the shank of the bolt, just part of the head. If you go the small chevy 4 x 4.75 pattern, it's worse. I've been 170mph on 'em, so I hope they hold. :lol:
PostPosted: Tue Jan 29, 2008 2:44 pm
how many times have them been re-drilled
PostPosted: Tue Jan 29, 2008 2:47 pm
one
PostPosted: Tue Jan 29, 2008 5:07 pm
Wonder what the 4 lug pattern on the fords and dodges are. Doesn't anyone make 6 lug draglites or something. I do have the 6 lug aluminum slots for a front. Guess they wouyld be lighter than the original steel or my pacers.
PostPosted: Wed Jan 30, 2008 4:38 am
Weld discontinued the 6 lug frontrunners. Also, the rotor is 2 piece, and the studs I forgot to mention are the Moroso's that you tap and thread the hole to install them. So you are actually adding 5 more bolts from the opposite side to hold them together. IMO, they are actually stronger than the stockers, as you have 11 bolts holding them together instead of 6.
PostPosted: Wed Jan 30, 2008 7:36 am
The ford and dodge are 4on4"
PostPosted: Wed Jan 30, 2008 9:49 am
Or spend a little extra and get a set of front runners and have them drilled to the pattern you want. In this case, 6 stud.
Bob.
PostPosted: Mon Feb 04, 2008 10:16 am
Found this information about rotor redrill. Seems to be a good price but does not include shipping. They are NHRA and IHRA certified so I would trust the work and the price does not seem outragous.
http://www.moserengineering.com/Pages/Shop-Services/shopservices.html
I am looking to install a V8 with a S10 rearend and I would like to keep the 6 lug pattern on front and rear. But you could do the reverse and have the chevy pattern all around. I am going to try and find a disk brake rearend see if the trooper front disk (vented disk) will be the same size and have a cheap 4 wheel disk setup.
PostPosted: Mon Feb 04, 2008 1:39 pm
Moser no longer provides this service.
http://forums.luvtruck.com/viewtopic.php?t=11628
PostPosted: Mon Feb 04, 2008 5:08 pm
thank you
It is strange that they still list it on the moser site.
