It is currently Tue May 26, 2026 6:49 am
 Post subject: LUV Transmission
PostPosted: Sat Jan 12, 2008 2:36 pm
Hi Guys...I just acquired a LUV stock tranny and I have a couple of questions..,.By the way the bell housing bolts to the trans, it appears I will have to remove the bell housing from the engine in order to change out the trans. Can I do this without pulling the engine??? ...or do I have to yank the whole thing out then replace the trans. It seem there should be a way to do this without pulling the engine because of the idea of installing a new clutch--- I wouldn't think it necessary. Maybe I'll have to raise the engine a little or something. Anybody have an answer??? Thanks a lot...Don.
PostPosted: Sat Jan 12, 2008 2:55 pm
what year is the luv i just put a new clutch in my 76 and i did not pull the motor i had to take out the trans mount and turn the trans on its side and work it a bit but it is out and in with out moving or pulling the motor
dangerous-toys4life
75 k-5 2x
94 king cab
 Post subject: Transmission
PostPosted: Sat Jan 12, 2008 3:24 pm
Hi Budbondo...Thanks for the reply. Mine is a '77. I guess if others have done it , I can too.
 Post subject: .
PostPosted: Sat Jan 12, 2008 4:25 pm
Had a 77 years ago. Changed clutch twice, never had to remove engine.
FIAA: Color Guard
Users browsing this forum: No registered users and 61 guests
