It is currently Sat Mar 21, 2026 1:10 am
 Post subject: JC Whitney Body Lift
PostPosted: Wed Jan 02, 2008 8:50 pm
I just ordered a 3" body lift kit from JC Whitney. Does anyone know if that is a quality kit? How much cutting/ is required? Does this kit include steering shaft extensions?
Thanks!
PostPosted: Wed Jan 02, 2008 9:32 pm
the kit SHOULD have the extension kit i would assume, Is it a "JC Whitney" brand body lift kit or is it "Perfomance Accessories" kit??? I have a PA kit in my S-10 and have had no problems with it, I also only have a 2" lift as I feel 3" is too much. And you run into problems with lines and steering shaft issues, and whatnot.
What do you meaning by cutting? :?
PostPosted: Wed Jan 02, 2008 9:36 pm
I have heard something about cutting a hole above the steering column, what is that for? I gues it's actually a PA body lift.
PostPosted: Wed Jan 02, 2008 9:43 pm
The hole in the fire wall where the steering shaft goes through will need to be opened up at the bottom for shaft clearance after the body goes up.
PostPosted: Wed Jan 02, 2008 9:44 pm
Are you sure it isn'e BELOW the steering column you're thinking...? Because lifting the body, won't cause a need for a hold ABOVE the steering shaft. Mo
PostPosted: Wed Jan 02, 2008 9:49 pm
Below does make more sense, that's why I was so confused.
Thanks for the input :D
