It is currently Fri Mar 20, 2026 11:50 pm
 Post subject: switchin to dana 35
PostPosted: Sun Dec 30, 2007 6:52 pm
i'm taking the independent out and want to put a dana 35 i'm not sure if i should go leaf spring or link system also i want to see about the hubs the new hub is a 5 lug and i want it to be a 6 what should i do???
PostPosted: Sun Dec 30, 2007 10:02 pm
Banishment Pending
I'd say screw it an sell the D35 and get yourself a Toyota Mini axle...already setup for 6 lug and is the perfect width. Leafs would be the easiest route to go..link=$$$$ lots of engineering goes into building and designing a link system that works well. alternately you could get ahold of a D44 out of a Wagoneer...or a Land Cruiser axle from a FJ60/62 or late FJ40
PostPosted: Sun Dec 30, 2007 10:04 pm
why would you wanna keep it 6 lug tho?
PostPosted: Sun Dec 30, 2007 10:50 pm
you can run the rims and tires that you got on your luv now and you get more options i got a set of 8lugs a bit wider but it will be fun to play with if i get to that point lol
dangerous-toys4life
75 k-5 2x
94 king cab
PostPosted: Mon Dec 31, 2007 2:11 am
Banishment Pending
cuz that's what it has...and most 4x4's are 6lugs = lots of rim choices
 Post subject: Re: switchin to dana 35
PostPosted: Mon Dec 31, 2007 11:46 am
you do realize that putting a dana 35 in place of the IFs is impossible...well i shouldn;t say impossible, but there's no good reason on earth why you would put an axle from the rear of a jeep that is ONLY made for the rear :P do you mean dana 30? if so... look for a dana 44 out of an early wagoneer.... in fact look for a PAIR of dana 44s from a wagoneer, front and rear and you then won't have to worry about lug pattern or strength. 8)
Leafs = Simple, Reliable
Link = Complicated, Flexy
PostPosted: Wed Jan 02, 2008 1:32 am
sorry my bad i dana 30 i thought about going and getting the dana 35 to put in the back so they matched but someone told me to take toyota mini axles then take the leafs from the toy a toy and put them on front and take some mid 80's chevy front leafs and put them in the back. something about good for good flexing witch i want to be able to do.
