It is currently Thu Jul 02, 2026 10:32 pm
 Post subject: Brakes.
PostPosted: Sat May 31, 2003 9:14 pm
I installed the 10 bolt rearend, what is the best way to hook up the small Luv brake lines to the bigger 10 bolt lines? Do I get an adapter to fit the small line into the bigger t-block. Can I use the booster and lines from the s-10 into the luv? I want to do this right, so your help is needed. :? :)
 Post subject: brakes
PostPosted: Sun Jun 01, 2003 12:13 pm
What i would do is go to a shop and have them make you a new rubber line that is the adapter with the right ends on each end. Then you have a new line and no worries at all.
PostPosted: Sun Jun 01, 2003 12:53 pm
I have a Chevelle 12 bolt in my luv.I used the stock rear hose to rear end,made new lines going to wheel cylinders,cut the inner section and used the stock fitting,then had it double flared.Works good
Users browsing this forum: Baidu [Spider] and 22 guests
