It is currently Mon May 25, 2026 11:24 pm
PostPosted: Sat Dec 29, 2007 2:01 pm
I have a 1980 Chevy Luv that is bagged in the rear , I am either looking for spindles or control arms for the front. Anyone know of anything that will interchange or where I can get either of these things ? Thanx
PostPosted: Sun Dec 30, 2007 10:13 pm
you might be able to get stuff from a pup and then order a spindle for it i planed on looking in to it put i just have not got to it sorry how low do you wont it you got pics of your luv
dangerous-toys4life
75 k-5 2x
94 king cab
PostPosted: Thu Feb 07, 2008 3:32 pm
Good luck finding something that will work. Your better off making your own upper and lowers!
PostPosted: Thu Feb 07, 2008 4:16 pm
pm sent
PostPosted: Thu Feb 07, 2008 5:11 pm
Just modify your stock control arms, thats what I did and I'm b/d 3 1/4" on the pinch
PostPosted: Fri Feb 08, 2008 3:44 pm
how's the lift with the stock arms. was probably gonna get some customs made but wondering how the stock geometry is with lift/lower of a body drop.
1980 Chevy LUV
PostPosted: Fri Feb 08, 2008 5:14 pm
Gonna have to pie cut the upper a little so the ball joint won't bind, because you gotta Z the frame to lay out in the front, the lift is good no problems
