It is currently Fri Mar 20, 2026 11:50 pm
Post new topic Reply to topic  [ 36 posts ]  Go to page Previous  1, 2
PostPosted: Tue Dec 18, 2007 2:22 pm
If the valve covers are bolted to the intake and if the pushrods are running through the intake its a mid size ford motor 332-428.If it doesnt have a huge intake then its a 429/460. A c4 would be a good choice for a trans but they wont bolt up to a mid sized FE or a big block. The c6 trans is huge and you would have to do some serious trans tunnel cutting.
Heres a pic of my 428FE does it look like this?
1975 V8 Luv
1980 Bagged Luv
PostPosted: Tue Dec 18, 2007 8:34 pm
http://s221.photobucket.com/albums/dd44/dustinmoen/?action=view&current=429bigblock.jpg
PostPosted: Tue Dec 18, 2007 8:45 pm
thats mine in that pic and if you look at my other pics the orange luv is mine ill put sum more pics of the truck n new motor soon
Is that the same as mine? Mine is a 429 big block out of a 1973 lincoln with a C6 transmission and a b&m shifter
what is that truck the motor of yours is in?
PostPosted: Wed Dec 19, 2007 4:07 pm
69 f100 Do you have any more pics of that motor?
It kinda looks like an FE
1975 V8 Luv
1980 Bagged Luv
PostPosted: Wed Dec 19, 2007 8:24 pm
Not an FE, those Y blocks had the dipstick coming through the intake, an FE has it out the PORT (drivers) side front of the engine...
BTW dan, did your 428 have that nylon-coated timing gear on it? If so how much of it was gone? Replaced mine after I found out what the nylon crap was in my drain oil, pulled the cover off and there was the aluminum part of the gear with no nylon and about a mile of slack in the chain, replaced with a summit double roller set 0*, might mess with the timing EVENTUALLY...
PostPosted: Wed Dec 19, 2007 8:53 pm
well my dipstick is right in front of the manifold and i dont kno much about a Ford engine so if i could get some info on how to shave some crap off the front of it that would be great, like if i could get sum the stuff inbetween the block and the fan taken off. i dont have emission testing here so what ever can be tossed id be happy to get rid of... and as for a radiator im thinkin about mounting it in the box. maybe an electric fan?
PostPosted: Wed Dec 19, 2007 11:07 pm
When I bought my engine it didnt have a cam in it so I dont know whether it had a nylon gear in it but the crank gear was metal.
Are you saying this motor is a y block? Its either a 322-428 FE or a 429/460.
Also count the valve cover bolts
5 is an FE
6 is a 221-351w
7 is 429/460
8 is 351C 351M 400
1975 V8 Luv
1980 Bagged Luv
PostPosted: Thu Dec 20, 2007 8:34 am
its got 7 bolts on the valve cover
i kno its a 429 tho :?
PostPosted: Thu Dec 20, 2007 11:20 am
Banishment Pending
5 is an FE
6 is a 221-351w
7 is 429/460
8 is 351C 351M 400
that would be correct then
PostPosted: Fri Dec 21, 2007 7:43 pm
i already knew what size it was all i need to kno is what needs to stay on it and what can be pulled from it... i have no emission testin and would like to get the most power out of this thing as i can :D
PostPosted: Fri Dec 21, 2007 10:31 pm
PITA Old Fart
Then just drill a big hole through the block, hook a big chain to it and use it to anchor a boat, and go get an SBC - preferrably a 350 4-bolt....lol
PostPosted: Fri Dec 21, 2007 11:08 pm
ya but iv already got this motor and everything that goes with it but that was what i really wanted to do so if i can find a 350 layin around soon i can sell this one to a friend that wants it but im not havvin too much luck findin 1 cheap
PostPosted: Sat Dec 22, 2007 2:52 am
PITA Old Fart
I bet there's a few guys around here that might know where to get your hands on one cheap. Post a WTB in the classified section and see what happens.
Ya might even be able to swap that f-word engine for one. A lot of guys here drive f-words for work trucks...but they'll never admit it here...lol
PostPosted: Sat Dec 22, 2007 11:48 am
ya im kinda embarrassed to admit my dad has an '04 f-250 diesel he just bought too. i give him shit about it everyday :P
PostPosted: Sun Dec 23, 2007 4:43 pm
332-428 is a FE
429-460 is a 385 series
And there are bell housings to fit C-4s to the 385 series engines.
Heh build what you want as the only real thing Chevy about our LUVs is the import name.
PostPosted: Sun Dec 23, 2007 9:37 pm
yah im not going this route any more... im going to try n sell or trade this motor and tranny for a 350 chevy
itl fit in there better, people have done this befor, and i kno a lot more about them
