It is currently Mon Jun 08, 2026 3:18 pm
 Post subject: height Q
PostPosted: Wed Dec 12, 2007 12:15 am
just wondering im 6' 4" and yesterday i decided im buying a luv to build into a pre runner. back to my question how well am i going to fit in a pre 75 luv. stock and/or with a cage
thanx
steve
PostPosted: Wed Dec 12, 2007 10:47 am
well, it depends partly on seat mounting heigth. I'm 6-1 and i fit in them ok, but i suggest you go out and drive one if it's possible...
PostPosted: Wed Dec 12, 2007 8:02 pm
I had a 75 that I ran in a tuff truck comp a few times and I was only 16 at the time, I was probably around 5'9". I had a roll cage and a 5 point harness in it. With the stock seat in it, the top of my helmet would bounce off the roof when I went off jumps, that was with the harness as tight as we could get it. So then I mounted the seat right to the floor with no runners and it helped. Normal driving or wheeling should be fine, but if you're gonna jump it at all, you might want to figure something out.
PostPosted: Wed Dec 12, 2007 8:12 pm
Can we say Sardine can :) Naw I'm six feet tall and I get in and out pretty easy and quick....I thought the same thing at first ...thought I was gonna hit my head all the time getting out or my legs on the steering wheel but Nope It's all good .....good luck ...
 Post subject: Re: height Q
PostPosted: Thu Dec 13, 2007 3:43 am
Australian LUV Guru
thanx
steve
I'm 6' 6" and after replacing the stock steer wheel with a much smaller one, i fit comfortably in my Luv even with the bench seat.
1980 4x4 KBD40 ISUZU/Chev Luv
PostPosted: Thu Dec 13, 2007 8:23 am
im only a 5'10" dwarf and i dont rekon theres stuff all room in a luv. Well the leg room doesnt make me happy anyways.
want to be careful what seats you use. If they are not a thin profile on the back you would loose leg room really quick.
Bob.
PostPosted: Thu Dec 13, 2007 2:32 pm
Bob is right about the seats, find some thin back buckets and mount them as low as possible and you can make A LOT of room compared to the stock bench. I'm 6' 2" and I fit fine in mine, but the 75 I had came with mid 70s camaro seats and it was a tight fit even for my ex-wife who is like 5' 10" or smaller. Comfy once you were in, but hard to get in and out of.
Users browsing this forum: No registered users and 61 guests
