It is currently Sat Dec 13, 2025 9:55 pm
 Post subject: v6 or 4cyl????
PostPosted: Wed Nov 28, 2007 1:05 am
i just got a 1977 luv with a stepside bed that had just started a swap to a 1976 buick 231 out of a sklark with a th350 tranny the motor is
bolted in with motor mounts and tranny mounts but needs plumping and wiring done and a drive line it still has the luv rearend. i also own a 1980 luv mikado 4x4 the motor runs good and i think it would be real easy to put in. any ideas wuold be great i dont know anything abought the v6 ive only worked on 4cyl. is it worth the rest of the swap? or is the 4 cyl a better idea i do plan on baggin the truck.
tim
http://s133.photobucket.com/albums/q69/frizzle_2/
pics of the truck
PostPosted: Wed Nov 28, 2007 1:12 am
check the numbers it looks like a 78 block even fire but could be a end of run 77 odd fire but the number doesn't match a 76 odd fire block.. i will be doing this swap soon but with a 5sp ...look at these numbers so you know what motor you have if you have to order parts
http://www.earlycj5.com/tech/engines/22 ... umbers.php
 Post subject: block #
PostPosted: Wed Nov 28, 2007 1:31 am
1254083 2
PostPosted: Thu Dec 06, 2007 12:14 am
Hey Ctmandu, what 5sp trans are you going to use for that swap. Lookin to do the same with my 78, but lookin for a newer engine. Maybe 3800 out of an 02 Camaro.
PostPosted: Thu Dec 06, 2007 12:35 am
well if i can find one out of a late 70's monza ill use it if not downey off road makes a bell housing to fit a toyota 5 spd to the 231
PostPosted: Thu Dec 06, 2007 3:21 am
I found one of the RX-7 conversion site are selling vg30 v-6 Nissan conversion mount . Looks like these are kinda becoming popular .
PostPosted: Sun Dec 09, 2007 11:41 pm
Wouldnt a T5 be easier???
dirtyluv, you might as well do it, youve got the big bits and thats a major part of it.
No way the motor out of the 4x4 will go anywhere near as good as the V6.
There are a few real easy bigger 4cyl conversions. A lot of newer 4cyl Isusu are an easy fit.
Bob.
PostPosted: Sat Feb 09, 2008 1:24 pm
ive decided to do the swap and im in the process of tearing apart the motor and i think it has aftermarket cams i dont know ive never done a rebuild before is hopefully i can find a manual on it dose anyone know of good websites with parts for this motor sorry for so many questions im still learning
thanks tim
PostPosted: Sat Feb 09, 2008 2:08 pm
I would check with Summit Racing. I have gotten alot of parts for my race truck from them and they have treated my real good. They have free shipping but a $10.95 handling charge. I bet they would have parts for your engine.
PostPosted: Sat Feb 09, 2008 3:01 pm
su7mmits good :wink:
thats a pretty nice lookin truk u got ther :D
PostPosted: Sat Feb 09, 2008 6:31 pm
Thanks. The pictures on the website are older pics so the truck has been updated a little. Your truck looks good too. I like Summit. Last summer the daughter, wife and I took a family trip out east and I had to stop at Summit. Pretty awesome store.
 Post subject: Re: v6 or 4cyl????
PostPosted: Wed Feb 13, 2008 12:18 am
ive gone to the parts store and they say there is no book for a 78 skylark dose anyone know of a book that covers this motor so i know what to tourqe everything to
Year CID Liter Bore Stroke Description Block Casting#
1978-77 231 3.8 3.80 3.40 V6, Even-Fire, Split Rod Pin Crank, Even Fire Engine 1254083
PostPosted: Wed Feb 13, 2008 9:50 pm
torque it real tight
PostPosted: Wed Feb 13, 2008 10:12 pm
:roll: :signimsorry :smt075
PostPosted: Wed Feb 13, 2008 10:15 pm
Or you got tightened it down until it breaks than back it off 1/4 turn!!!!
PostPosted: Wed Feb 13, 2008 10:25 pm
i have a tourge wrench. i thought the same thing i did that on a 86 mercury couger it worked for a week
PostPosted: Thu Feb 14, 2008 12:43 am
yeah i was NOT serious. get the specs first
PostPosted: Thu Feb 14, 2008 6:27 am
What happened to the good old days when the torque specs for the gaskets were on the packets they came in.
Bob.
