It is currently Wed May 06, 2026 8:50 pm
PostPosted: Wed Nov 28, 2007 1:55 am
Was there a S-10 made in 1982?
Found a site that shows Rocker panels for a 1982 S-10. And just wondering if there the same as a 82 luv?
May order one and see if it can be worked in on my truck.
Pete
PostPosted: Wed Nov 28, 2007 2:32 am
yes there is a 82 s-10 but it is not the same as the 82 luv/pup if you wont the s-10 82-88 will work the same they are the box ones it came with the isuzu 4 banger in 82 not sure if it came in the 83 but will you get a pic of what part is bad that will help if you need s-10 parts you can go to (LMCtruck.com)or call and get a catalog its toll free(1-800-541-8525)
dangerous-toys4life
75 k-5 2x
94 king cab
PostPosted: Wed Nov 28, 2007 8:55 pm
Thanks its the rocker panels for the 82 luv that I need. Mine are gone and part of the cab on the back that the panels connect to also.
Guessing if i do not get some made I will just drive it like it is.
Thanks again.
Pete
PostPosted: Wed Nov 28, 2007 9:52 pm
you might be able to get it at a junk yard like pick your part if you get sum pics of your truck good pics of the bad parts someone her me or someone else can maybe find it for you cut it out off of a truck where ever we can find a truck with the good parts you need and ship it to you i don't think it will cost to much if that needs to be done but i think if you look for a custom shop like the one i work or a good body shop they can get what you need or make it like i have done but for like me i need the truck in front of me to go from a-z i hope that i have helped a little bit
dangerous-toys4life
75 k-5 2x
94 king cab
PostPosted: Thu Nov 29, 2007 1:36 pm
Thanks I will get some pictures of it soon. I have to unload the bed. Right now its full of junk and needs to be cleaned out. Then I will get it home.
The old truck looks bad. but its a good old truck.
Someone told me that the ones out of a Pup would work. If so I may be able to come up with some like that.
Also I have a wire welder. So getting them back in will not be hard.
You would think a company would make these pieces and market them.
Pete
Users browsing this forum: No registered users and 56 guests
