It is currently Tue May 26, 2026 12:48 am
 Post subject: Cadillac wheels
PostPosted: Thu Nov 15, 2007 1:00 am
I have been freequently checking e bay for 6x5.5 wheels, especially the excalades. I know allot of people use the 17" smooth lookin ones, but the escalades also came with 18" like 5 or 6 spoke wheels, with a 31mm offset, anyone know if i would have issues fitting these on my luv?
thanks :) [/img]
PostPosted: Thu Nov 15, 2007 6:43 am
You need to check the center bore and the dept from the back of the center cap to the mounting surface of the wheel. The luv has a bigger bore than some other 6-lug trucks and the height of the front hub off the mounting surface can be hard to get under a centercap. Look under "PUT MY 20" WHEELS ON TODAY" One of the members named: bagged79 has the eske wheels.
If your going to 18" wheels why not just jump to 20"? That's what I'm putting on my truck.
PostPosted: Fri Nov 16, 2007 10:20 pm
Hey thanks for the suggestions man, ya i ile just ask about the center bore, and if its not big enough, i guess i can always get the front ones machined, and 20" would be sick, i mean they look great on your truck, but i think 18"s are just more the look ime going for
PostPosted: Sat Nov 17, 2007 9:14 am
Good luck with the build.
PostPosted: Sat Nov 17, 2007 8:50 pm
I had 31" tires under my 4x4. If you can fit rim to the hub, the 18's will fit, but it depends on the tire on the rim.
Take the width, say 255mm. Take the aspect ratio, say 55's. The aspect ratio is a percentage. So multiply the 255 by .55. you have multiply that by 2 to account for rubber on each side of the rim. That's equal to 280.5. A mm is equal to .03937 of an inch. Multiply 280.5 x .03937 and thats equal to 11.04. Add the 18 inch rim and you have 29.04.
Like I said, I had 31 inch tires. Now on the 1980 4x4, the front hub isn't centered in the middle of the wheel well. When I brake hard, I would rub some on the back of the wheel well where the mud flap is. I think with 18's w/ a 55 series tire you would have plenty of room and still look great. Let me know if you need any help.
Emo
PostPosted: Sat Nov 17, 2007 10:26 pm
18" escalades need to have the center bored to be able to fit in the front, not sure how much though. +31mm offset if you plan on baggin is perfect, that is the same offset as my 17" eskies and the same offset as the silverado wheels like "Dan" & "Pee_Roy" have
PostPosted: Sun Nov 18, 2007 1:51 am
Dang thats allot of calculations! but thanks emodx. I dont think i will have to much trouble with tire size though on account of the rubber bands i am getting on the wheels hahaha.
And thats good to know the 31mm offset tucks nice, eventually i want to bag mine so that will work good. those powdercoated 17"s look sick by the way
PostPosted: Sun Nov 18, 2007 10:08 am
Believe it or not they are actually painted not powedercoated. The color is 07 Freightliner Metallic Black, thanks for the compliment!
PostPosted: Sun Nov 18, 2007 3:24 pm
man i luv your luv you did a great job on it.is it getting shot for a mag do you have pics of the motor like a lay out she is sweet
dangerous-toys4life
75 k-5 2x
94 king cab
PostPosted: Sun Nov 18, 2007 7:12 pm
I got shot for a feature for Mini Truckin on September 30th at the Dropt-N-Destroyed show in Akron, Ohio. I actaully don't have an updated pic of the engine compartment, but this winter the firewall is gonna be shaved, trailer fenders will be installed, and batteries will be relocated so there won't be any wires seen. Hopefully gettin a turbo for the 231 also.
PostPosted: Wed Nov 21, 2007 5:50 pm
have you thought about putting a tilt bed on with it being a long bed that would look soo kool
dangerous-toys4life
75 k-5 2x
94 king cab
PostPosted: Fri Nov 23, 2007 8:13 pm
I have thought about it, but decided not to because I'm stock floor B/Din it this winter
PostPosted: Mon Nov 26, 2007 9:43 pm
It is called hub centric or lug centric. I nephew truck had Caddy wheels on his Isuzu when he bought it.. The hub hole is the wrong size like people have said. His truck has 5 lugs from the factory. 90's something Isuzu truck. It would cost more to have the wheels cut than it was worth, plus he could not find anyone local to do it. He just bought new wheels.
PostPosted: Tue Nov 27, 2007 5:04 pm
I'm lucky, I work right beside a machine shop and they re-drilled my s10 axles/hubs for free :lol:
PostPosted: Sat Dec 01, 2007 7:21 am
so you put a s-10 rear end under the luv i have a full frame (s-10) that i was going to put under my luv but i am sloooooooooooooooooooow at it i was going to put the luv cab,bed and then get the motor mounts from a 82 s-10 that had the 1.8 isuzu motor in it so it all will go together right what do you think i do it i got the frame with a monster notch in it rolling frame for cheap ok thanks for the help
dangerous-toys4life
75 k-5 2x
94 king cab
 Post subject: Re: Cadillac wheels
PostPosted: Thu Apr 10, 2008 2:09 pm
I know this is an old post, but i wanted to clear something up.
the 18" Escalades fit like a dream, and you DO NOT HAVE TO BORE THE CENTER!
I got mine a couple days ago and the caps even fit on in the front without any machine work.
they tuck nice to!
i included a pic of the ones i am talkin about
PostPosted: Thu Apr 10, 2008 8:59 pm
Looks sweet.
PostPosted: Mon Apr 21, 2008 3:45 pm
I'd like to clear something up also! Those are a diffrent year wheel than Bagged79 has. do you know the center bore demensions of the newer eskies? I had the same eskie wheels as Bagged79 has on my Nissan and they HAD to be bored. they used the same center bore on the older caddie wheels as they used on the older Z71 wheels and THOSE MUST BE BORED TO FIT!!!!
PostPosted: Tue Apr 22, 2008 10:42 pm
sorry i dont know the exact deminsions.
But ya your right you have to bore the 17's.
I was just wanted to let people know the 18's fit.
To bad the grease cap sticks out so much huh
PostPosted: Wed Apr 23, 2008 5:45 am
Have you looked into replacing the caps with other ones? I was going to look into trailer axle caps before I purchased the 20" with the correct bore demensions. try looking at http://www.redneck-trailer.com/ they have a crap ton of axle parts and you might be able to get a smaller cap.
