It is currently Mon Jun 08, 2026 3:11 pm
PostPosted: Sun Nov 11, 2007 2:59 am
the little studs or pegs how ever u want to call them broke off of all my emblems
PostPosted: Sun Nov 11, 2007 4:11 am
I broke my emblem pegs when I removed the emblems. I used J.B. Weld to put them back on. Not sure how that will hold up since I haven't put the emblems back on yet.
http://www.purerockradio.net/
PostPosted: Sun Nov 11, 2007 10:22 am
I had one peg broken on one of mine. I just used a little silicone to glue it back on.
PostPosted: Sun Nov 11, 2007 1:05 pm
3M makes an emblem and molding adhesive. It should be available through most parts stores. Just clean the surface of the emblem that will contact the surface of the truck and put a SMALL amount on the emblem surface. Let it get tacky and press in place and make sure it is stuck. You can put a little tape on it to hold it in place until it is dry, especially if it is a heavy item.
PostPosted: Sun Nov 11, 2007 9:05 pm
Mine are on without pegs using 3M double-stick tape. I got a roll of the same kind they use for putting on molding and re-attaching exterior chrome pieces, cut pieces to fit the emblem (kind of a pain in the butt - but it works) and I've never had a problem with them coming loose.
PostPosted: Mon Nov 12, 2007 7:20 pm
3m double sided tape works wonders! :)
PostPosted: Mon Nov 12, 2007 7:51 pm
the luv emblem on the back is with 3m worked great and have never had a problem... still tight and its been threw 2 winters and a few car washes...I used the 3m that’s about 1/2 wide with the red plastic film that you peal off the attach it
PostPosted: Tue Nov 13, 2007 8:19 pm
yeah i lost the pegs... i gota go back to pick a part in ontaio ca abd see if the 75 has a power steering pump if it does im gona take every thing for it and than get the resvaurs for the coolant and windshield wipers
 Post subject: .
PostPosted: Tue Nov 13, 2007 9:25 pm
3M double stick.
Or if ya have a buddy with a body/repair shop, he'll have exactly what you need.
FIAA: Color Guard
Users browsing this forum: No registered users and 56 guests
