It is currently Mon May 25, 2026 11:07 am
 Post subject: weatherstripping
PostPosted: Mon Nov 05, 2007 7:54 pm
I found someone who says they have or can make weatherstripping.
restorationspecialties.com
This is the E-mail.
The only thing that I would do is to actually talk to the guy/ company. Because I sent the e-mail on sept 26th and didnt get a response till Oct 29th.
I have door weatherstripping
----- Original Message -----
To: info@restorationspecialties.com
Sent: Wednesday, September 26, 2007 5:30 PM
Subject: Chevy LUV
Hello!
I just found out about your company and wanted to find out if you carried any Chevy LUV parts.
I am in the middle of restoring a 78 Chevy LUV and I am need of some body mounts and bolts, can you help?
Thanks for your time,
Erron
PostPosted: Mon Nov 05, 2007 8:47 pm
Call them. They are good people. You tell them LUV and they know the weatherstripping to send you. I just installed it into my 4X4 yesterday, and I did my 80 a while back. It works well. You have to cut and glue to make the 90 at the top of the window, but that's the only hard part.
As for window channel. I sent them a piece out of my truck. They sent me 3 close choices to figure out which one fit best. I have it figured out but have not called to order any of it yet. If you want the part numbers, let me know. I can give them to you. I would do it now, but it's out in the garage, and I'm in for the night.
PostPosted: Mon Nov 05, 2007 11:24 pm
Yeah they make great weatherstripping. I ordered enough for 2 trucks back in the Spring. You have to call them. Their service was speedy too. I didn't do a 90 cut on my door corner, I just went right around the bend with it. Should I have cut it? I really wanted to try to keep it all one piece to avoid having issues with it coming apart at the corner.
http://www.purerockradio.net/
PostPosted: Tue Nov 06, 2007 12:50 am
i still like the 70/80's dodge d-50 , mitsubishi.. it already has the sharp corner, fits right in and is just a hair bigger wich eliminates wind noise and almost every one i have found is still like new unlike the luv ones
PostPosted: Tue Nov 06, 2007 5:45 pm
Where do you get the D50 weather stripping?
PostPosted: Tue Nov 06, 2007 10:00 pm
wrecking yards, they usually charge me $5 a door
PostPosted: Tue Nov 06, 2007 10:48 pm
Those trucks are few and far between down here on the gulf coast .
PostPosted: Tue Nov 06, 2007 10:55 pm
Well maybe this summer ill have to start scavenging some for people on here
PostPosted: Wed Nov 07, 2007 9:24 am
I must have missed somthing about Luv restoration.com, I see they have been closed for a long time. But when I was doing my 79 4x4 I ordered door weatherstripping from them and was very happy with it. But I guess there gone... :cry:
PostPosted: Wed Nov 07, 2007 8:53 pm
Fresh weather strip would be sweet .
PostPosted: Wed Nov 07, 2007 9:39 pm
LUV restorations has come and go a a time or two.
The seals I got are from a place that just makes and sells seals and seal parts for everything. Here's a link.....
http://www.restorationspecialties.com/
PostPosted: Wed Nov 07, 2007 9:53 pm
I had a neighbor in Port Angeles, Wa. that specialized in aircraft and older vehicle weatherstripping. He told me he had a website and what not, I think he even showed me his shop at one time.
He even had to get his Nova or Chevelle out of our garage when we moved into the house that he was working on.
I didnt have my LUV back then, but man I sure wish I could remember his name now.
PostPosted: Fri Nov 30, 2007 11:48 pm
I installed window channel from Restoration Specialties tonight. Nice fit, easy to do. Window is tight and goes up and down smooth. They should have the part # in their system if you call them.
They shipped enough for 3 trucks to me for $82.00.
The part number is AS-1264.
 Post subject: Re: weatherstripping
PostPosted: Wed Jan 04, 2012 12:26 pm
An order was just placed to Restoration Specialities by phone. Their number for the door weatherstripping is #990021. It takes 24 feet to do both doors and runs $2.00 per foot. An email was sent yesterday with the response to call the order in today. They are sending samples of chrome lock strips for the front windshield also. Hopefully they have a match. :)
PostPosted: Wed Jan 04, 2012 2:53 pm
Thanks for the heads up on the window weatherstrip!
I could use some myself! :D
