It is currently Wed Jul 01, 2026 12:04 am
Post new topic Reply to topic  [ 80 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Tue May 20, 2003 5:48 pm
Resident Sparktrician
OK, quick update. It looks like the G180(1.8,1817cc) and G200(1.9,1949cc) shared the same block, but the 1.9 simply had a larger cylinder diameter. This means that the head should swap over. Also, the parts came in from Matt Johnson (thanks to Ben for posting his stuff for sale in the classified section), so I now have the electronic ignition and Crane cam in my posession (both are new and look great). Well, pics are still to come, but i'll do my best to get them up soon. The machinist has been notified and is ready to go :lol: :twisted: !
Laterz...
Kuranosuke
Grampa's Driving:
1990 Luv 4X4 "Family Cab"
got BOOBIES? 8O 8)
PostPosted: Tue May 20, 2003 9:16 pm
Ok, as promised, here are a few pics.
When I saw this, I almost freaked
Pistons
Crank
Side shot
Top shot
The mechanic
Well, it may not look like much, but I think this is the one I'll be going with (pending the ok from the machinist).
Laterz...[/img]
Kuranosuke
Grampa's Driving:
got BOOBIES? 8O 8)
PostPosted: Tue May 20, 2003 9:35 pm
why, or how is this engine going to be faster and stronger? it looks like its stock? looks like my shity 20R will beat u :twisted:
PostPosted: Tue May 20, 2003 9:48 pm
Where should I start? Let's see bigger cam, rejetted Weber carb, header, larger displacement in the block (albeit not much, still larger), custom exhaust, and the list goes on. I'm not looking for speed on the road, though (you should already know that from the chat). You can, however come and see me off road anytime you'd like :lol: :twisted: ...
Edit: Oh yeah, and my ugly mug will make your 20r yelp like a kicked mutt! :lol:
Kuranosuke
Grampa's Driving:
got BOOBIES? 8O 8)
PostPosted: Tue May 20, 2003 11:13 pm
OG Lifer
Man you need to dump that 20R and go with a 22R. Bigger is better and according to my father and the original LUV truck guru in my family, "There is no substitution for cubic inches"
WATCH YOUR PIEHOLE!!!!!!
PostPosted: Tue May 20, 2003 11:37 pm
why go 22R when u can go 350? :twisted:
PostPosted: Tue May 20, 2003 11:41 pm
OG Lifer
Why go 350 when you can go 454? No sub for cubic inches my man. none whatsoever. :twisted:
PostPosted: Wed May 21, 2003 12:22 am
why go with one engine? why not 2 or maybe 3 :)
PostPosted: Wed May 21, 2003 8:05 am
OG Lifer
OOOOOOOOOHHHHHHH how bout a turbine engine mounted in the bed? JT-8D or CFM-56?
PostPosted: Wed May 21, 2003 1:46 pm
i've been thinkin of making my luv a wheelie truck. drop a 350 in the bed :twisted:
PostPosted: Wed May 21, 2003 3:54 pm
you watched monster garage monday night didnt you? :lol:
i am thinking of doing that to a old POS s-10....FUN FUN FUN!!!! 8)
PostPosted: Wed May 21, 2003 4:40 pm
do sme port work on your head from what i`ve seen they could use some help. match up the intakes and the exhaust clean up the bowls a little. that will help with power some just dont get to aggressive with it you don`t want to lose your bottom end torque for 4 wheelin.
PostPosted: Wed May 21, 2003 6:10 pm
I thought about that, but it is so damn expensive to get head work done around here. Can I do this myself without screwing it up? I have a Dremel tool. What else would I need?
Kuranosuke
Grampa's Driving:
got BOOBIES? 8O 8)
PostPosted: Wed May 21, 2003 6:46 pm
do not try to port your head w/ a dremel.....what you need is a air powered die grinder...a pressuer regulator......and a junk head to pratice on.
i use to have a link to a pretty good set of instructions for head porting.....but i dont know where it went :x .
i match ported my buick 3.8 heads myself
PostPosted: Wed May 21, 2003 6:49 pm
A perfectly junked head I have :lol: , a grinder or compressor I don't :cry: . Oh well, I'll see what I can get into.
Does anyone have a Weber 38cfm carb they want ot get rid of?
Kuranosuke
Grampa's Driving:
got BOOBIES? 8O 8)
PostPosted: Wed May 21, 2003 8:02 pm
:lol: :lol: yeah. i thought it would be alot harder than that. i haven't seen a wheelie luv and you know it would be badass. that was my first thought when i got the luv. i was thinkin a v-8 in the bed but at the time i didn't know you can get one to fit under the hood :lol:
PostPosted: Fri May 23, 2003 10:13 pm
Well, the 1.9(G200) that I have turns out to be good. It has been honed and cleaned, so all I have left is to figure out the head problem, order new rocker arm for the cam install, get rings, get rod and main bearings, and crind the crank to .010 under. It's going to come together quick once I get the head figured out.
More to come...
Kuranosuke
Grampa's Driving:
got BOOBIES? 8O 8)
PostPosted: Wed May 28, 2003 8:12 pm
OK, the crank came back today. The shop that I took it to has a gorgeous shop. It's a tractor repair facility. $65 to get the grind done, and it is beautiful. I ordered the rod and main bearings as well as the new rocker arms. $300 total today (ouch), and I just have to settle the bill for the parts cleaning/head work at NAPA (~$80). A new timing set, which I would like to get runs $130 for the 1.9 (double ouch). It looks like my early estimation of ~$600 for the total build is going to be right on. More to come...
Oh, and I still don't have a head. I guess I'll probably use the one off of my truck. Also, I have a set of white faced gauges (oil temp, water temp, and oil pressure) in the boxes that I'll let go for $80 + shipping to anyone that wants them. These are electrical gauges and cost me ~$100 + shipping. I bught them for my car, and decided not to install them. I wired up the lighting and did a test fit, but that is all they have been out of the box for. Let me know...
Link to the website for the gauges: http://www.acautotechnic.com/achome.html
Kuranosuke
Grampa's Driving:
got BOOBIES? 8O 8)
PostPosted: Fri Jun 06, 2003 8:03 pm
Well, this was the last day of class for the term, and I only had one class, so I got some work done on the motor. I tanked, blasted, and painted the crank pulley, timing cover, and valve cover (this was the only thing tanked). I tanked and tumbled all the internal head components (rocker shafts, springs, washers, etc). I also got the block decked and washed (again). Alot of cleaning, but when the engine goes together its going to look awesome. This will probably be the best looking, and most professionally done, block that I've built. I also got the wrist pins lubed up and rings on the pistons. On Monday, I should be putting in bearings, pistons, and crank. The head will be here in about 2 weeks, and all that's left there is build up with the new cam, rocker arms, and clean parts. I'm going with a cast iron colored block and gloss black valve cover, timing cover, etc. I'll get pics on Monday (I hope).
More to come...
Kuranosuke
Grampa's Driving:
got BOOBIES? 8O 8)
PostPosted: Fri Jun 13, 2003 9:12 pm
Finals were done yesterday! Today I have a short block. The crank and pistons went in today. BIG MILESTONE. :D The block is Cast Iron high temp paint and all the pulleys and covers are gloss black. It looks really nice. The head will be in my possession on Sunday and should go together on Monday. I am debating on whether I want to spend $500 on a Trooper tranny/xfer case. A lot of money, but a good investment. Anyway, the rest of the motor will hopefully be back together on Monday and pics will quickly follow. Practically every part on this project was bead blasted (down to the timing cover and oil pump bolts) so it should turn out pretty clean.
More to come...
Kuranosuke
Grampa's Driving:
got BOOBIES? 8O 8)
