It is currently Mon Feb 02, 2026 2:59 pm
 Post subject: th350 tranny mount
PostPosted: Fri Sep 14, 2007 9:52 am
does anyone know the measurements of the swap bracket bolt holes from the crossmember bolts to the tranny mount bolts thanks
 Post subject: mounts
PostPosted: Fri Sep 14, 2007 12:46 pm
I have my motor out of the truck right now. I could measure the holes for you if no one else does before tomorrow. Where in missouri are you located? :fist:
PostPosted: Sat Sep 15, 2007 9:15 pm
i'm in maryville, mo about 1.5 hours from kansas city, mo. if you could get them measurements i would appreciate it. thanks
PostPosted: Wed Sep 19, 2007 6:38 pm
Cool, i am in Jeff City
Do you just want the distance from the front of the cross member to the tranny.
You know it makes a difference how far you motor sets back if you are making your own mount. The farther back the closer the tranny is to the cross member.
 Post subject: mount
PostPosted: Thu Sep 20, 2007 6:29 pm
yeah i think i got it figured out now thanks
PostPosted: Tue Oct 02, 2007 4:18 pm
Is anyone running a TH200R-4 in their Luv? What's the difference in the tranny crossmember? Isn't a 200R about the same length as a TH350?
