It is currently Thu Mar 19, 2026 3:42 pm
 Post subject: Getting Fed up
PostPosted: Mon Sep 03, 2007 5:48 pm
I am getting fed up trying to line up my fenders and door's right but i cant figure it out each time I think i have it my door connects with the fender on either side and it pops the metal each time I need some advice.
 Post subject: Fenders
PostPosted: Mon Sep 03, 2007 6:09 pm
hout looking at it sounds like you might need more of a gap beteewn the doors and fenders.
PostPosted: Mon Sep 03, 2007 7:41 pm
are you moving the fender or the doors they both have some play in them
PostPosted: Wed Sep 05, 2007 9:43 am
The fenders mainly but i toyed with the doors too and it is all giving me greif
PostPosted: Wed Sep 05, 2007 10:59 am
-What size gap do you have on both sides (cab side and fender side ?)
-Are there or were there shims on the doors or fenders ?
-Did you drill any alignment holes ?
The shims are eeeevil if you forget one, add one too many ect.
Austin
PostPosted: Wed Sep 05, 2007 7:49 pm
fenders original or aftermarket
PostPosted: Wed Sep 05, 2007 8:27 pm
The fenders are from my 76 cab and they are going on the 74 also the gap space is about half inch give or take
PostPosted: Wed Sep 05, 2007 9:11 pm
Half an inch on both sides ?
-A
PostPosted: Thu Sep 06, 2007 12:20 am
yea probably a little less
PostPosted: Thu Sep 06, 2007 12:22 am
sure it hasn't been hit in the front, fenders should fit no mater what year
PostPosted: Thu Sep 06, 2007 12:25 am
you didnt pinch the head light wires or side markers between the fender and body did you that would give about 1/2 inch gap
PostPosted: Thu Sep 06, 2007 12:29 am
no that's the thing this is just doing a mock up I think i may have to tac them in place and redrill new holes so it all lines up
PostPosted: Thu Sep 06, 2007 10:34 am
Do the inner fenders or framing structure look out of whack to where you think that truck has been punched in the nose ?
-A
PostPosted: Thu Sep 06, 2007 11:35 am
When messing with the door, remember you can make changes in 6 directions. If it is hitting the fender it could be that the door is too far out or in. The other thought that comes to my mind is that there may be a little bit of bow to the fender that shouldn't be there. The two bolts at the bottom of the fender have some play to sort of stretch the fender out a little so you could try to pull down that bottom lip or push in on the middle of the fender while you tighten them down.
They can be a bear to get aligned right, but at least LUV doors are not that heavy. Try holding up a 200lb 76 Camaro door with one hand while trying to tighten the bolts with the other. :)
PostPosted: Fri Sep 07, 2007 12:39 am
good idea and also the frame is straight
