It is currently Tue Dec 09, 2025 7:55 pm
 Post subject: transmissiom fluid ?
PostPosted: Fri Aug 24, 2007 10:26 pm
I have a 1980 4x4 luv with a standard transmission that has a small leak in the rear main seal. What kind of fluid does this transmission call for and how much does it call for.THANKS FOR YOUR HELP :?:
PostPosted: Fri Aug 24, 2007 11:07 pm
I put 80/90 weight in my 79.
PostPosted: Sat Aug 25, 2007 6:51 am
Australian LUV Guru
You should be useing engine oil your trans. 8O
Mace, you should change your oil.
1980 4x4 KBD40 ISUZU/Chev Luv
Australian LUV Guru
 Post subject: trans ?
PostPosted: Sat Aug 25, 2007 10:19 am
Thanks for the help
PostPosted: Sat Aug 25, 2007 2:41 pm
Hey OZ...way to show 'em how to RTFM! :lol:
 Post subject: .
PostPosted: Mon Aug 27, 2007 4:20 pm
I tried motor oil and it ran out like water. Guess I'll have to change the rear trans seal. Does anyone know how big of a job this is and I called a parts store about a seal they had 2 differant ones. How do you tell the differance between a g180 trans and a g200 trans? I think thats the trans numbers he told me but im not sure
PostPosted: Mon Aug 27, 2007 6:43 pm
If this is the oil seal at the rear of the trans where the driveshaft comes in, this is not a bad repair at all. Just did it maybe 6 months or so because mine was leaking. It's a round seal with a spring on the back if that's it. I got mine at Napa. Drained my tranny, unbolted the driveshaft at the rear, slid it out, pulled out the old seal and put the new one in. The shop manual said to use a special tool to install with, but I used a piece of PVC pipe to install my new one with. I don't remember what size pipe. Whatever it was, I just cut it off square and tapped the new seal in with it until it was seated. The PVC was a perfect fit.
There will be someone else around who can tell you how to tell which tranny you have. I would guess g180. I don't remember them even asking me that question.
Edit: Just figured out we were talking 4x4, mine is a 2wd, don't know if that makes a big difference or not since I don't know crap about 4x4s.
1980 2wd Stock
