It is currently Mon Jun 08, 2026 6:44 pm
 Post subject: Advice on removing bed
PostPosted: Sun Aug 12, 2007 12:37 am
Looking to remove a bed off a parts truck to put on my runner. Does anyone know how to perform this operation and if you have any tips for me for removing a bed from a mid-to-late 70's luv? thanks for any help in advance.
PostPosted: Sun Aug 12, 2007 1:06 am
Well it is more simple than you think. . .
-Remove all the electrical off of the bed
-Remove the fuel system plumbing (fuel inlet and such)
-Remove rear bumper (makes it easier for grabby purposes)
-Remove the eight (8) big huge bolts holding the bed to the frame
-Remember this would be a good time to paint any of the parts on the frame or the frame itself before your bed goes over it.
-A
P.S. Having a lot of buddies around for this one would be a lot of help just to make sure it drops in on one fail swoop !
PostPosted: Sun Aug 12, 2007 3:48 am
The center bolts on each side are attached to the bed, so just the nuts loose on those 2. The set of bolts behind those towards the tailgate have the squares on their heads, so no need for a wrench up in there, just loosen the nuts on those. The other 6 are nuts and bolts. As was mentioned above, remove all the wiring (tail lights, marker lights, license plate light) and all the fuel lines that go to the evaporator tank. I marked each nozzle on the evaporator tank and each fuel line with a corresponding number on masking tape so I would make sure they went back together properly. The fuel filler hose screws need to be removed too. I left the hose attached to the tank and just left it hang there, but it would probably have been easier to remove it from the tank or bend it down and tie it so it will be more out of the way when you lift the bed off. I had my bumper already off and the tailgate off as well, that would make it as light as possible. A couple guys can get it off and on, but more people would be easier. It can't be too hard since I never knew anything about it before i did it. Just keep track of everything you undo for when you put it all back together. Good luck!
http://www.purerockradio.net/
