It is currently Mon Apr 06, 2026 2:51 am
 Post subject: Steering joints?
PostPosted: Fri Jul 20, 2007 3:39 pm
I've found new tie rods and upper ball joint on the internet, but what about lower ball joint and the main steering linkage ball joins and idler arm ball joints? How can I replace these since they are built into the arms and not just replacing the ball it'self?
PostPosted: Sat Jul 21, 2007 8:11 am
I got all that from partsamerica.com
 Post subject: Re: Steering joints?
PostPosted: Sun Jul 29, 2007 2:49 pm
What year Luv do you have? I have replaced both upper and lower ball joings, tie rods, and I think the idler arm ball joints. I think they juse unscrew off lik the tie rods. Mine is a 80 Luv 4x4. Do you have a
shop manual to look at?
PostPosted: Sat Aug 04, 2007 3:03 pm
no, I don't have a manual. I found the uppers and the tie rods, but the ideler arm, the steering arm, lower ball joints, and adjustment link i can't find new or rebuilt. i'll try that website though.
Edit: I own a 1973 luv
PostPosted: Sun Aug 05, 2007 7:00 pm
I would keep checking back on here.
I am sure there are other 73 owners on here and they well help you find the parts. I used Napa parts online (not sure on url address), but I found some parts online I coudnt get at the local store.
Also on aother post in the Body and Chsses section, there are people doing some fabrication with ball joints:
http://forums.luvtruck.com/viewtopic.php?t=11679&postdays=0&postorder=asc&start=280
