It is currently Sun Jun 07, 2026 1:16 pm
PostPosted: Wed May 14, 2003 8:51 pm
Resident Sparktrician
I don't know, maybe it's just me, but I don't think the stock tranny would require that much trimming. Can anyone guess what it might be? My 4x4 stuff is still hooked up as it's supposed to be... :?
Kuranosuke
Grampa's Driving:
1990 Luv 4X4 "Family Cab"
got BOOBIES? 8O 8)
PostPosted: Wed May 14, 2003 9:00 pm
8O damn!!!
im gonna guess and say it IS the stock trans...but someone put a 2wd cab on :?
PostPosted: Wed May 14, 2003 9:04 pm
I just thought of something. If the body was lifted, would the tunnel need to be trimmed for all of the gears to be hit? The shifter is larger at the top after all...
Kuranosuke
Grampa's Driving:
got BOOBIES? 8O 8)
PostPosted: Wed May 14, 2003 9:49 pm
OG Lifer
Yup. The little truck I just bought had a body lift on it and teh previous owner had to trim the tunnel to make it go into gear.
WATCH YOUR PIEHOLE!!!!!!
PostPosted: Wed May 14, 2003 10:45 pm
Good. That's a relief. That means the new clutch set I just bought will fit. Thanks guys!
Kuranosuke
Grampa's Driving:
got BOOBIES? 8O 8)
PostPosted: Wed May 14, 2003 11:12 pm
yeah in stock trimm the shifter just clears the body, if you have a boddy lift it will through all of that out of wack. :?
PostPosted: Thu May 15, 2003 6:26 am
Was the original boot on ? I cut mine out and went with a metal framed boot that was a little larger than the hole.. When i put my lift kit on , it said you have to cold bend the shifter in third gear...that was a scarry thought...but it worked out ok. If you follow your steering colum inside to the firewall you well probly notice that it has been cut to fit also! Hey another thing, look under your bed where it is setting on the spacer blocks and make sure that who ever lifted it spot welded the four metal spacers in the center to the frame.If your shifter housing wasent cut...you would only have 1st..and..3rd..Might be a slow ride!!
PostPosted: Thu May 15, 2003 6:32 am
whats the little chrome switch under your heater?
PostPosted: Thu May 15, 2003 12:32 pm
OG Lifer
From the angle it looks like a manual choke pulloff.
PostPosted: Thu May 15, 2003 4:30 pm
Auxiliary 12v outlet. I pulled the ashtray for something else. Don't worry, those pics are coming too. :wink:
Kuranosuke
Grampa's Driving:
got BOOBIES? 8O 8)
PostPosted: Fri May 16, 2003 11:01 pm
That is most definitely body lift trimming. Your truck has like 3 inches or so from what I saw, which would require a fair amount of cutting. While you have it all open like that you should take a look at how well 4hi and 4lo clear and maybe do some more cutting it you have trouble keeping the tcase shifted in. I only have a 2 inch lift and 4LO bangs itself out against the cab, especially when backing up.
PostPosted: Sat May 17, 2003 12:13 am
The clearance is good except for second gear. I get a rattle while its there, but it isn't hurting anything. It's just the shifter vibrating against the tunnel. The carpet is not going back in, by the way. I have to figure something else out.
Kuranosuke
Grampa's Driving:
got BOOBIES? 8O 8)
PostPosted: Sat May 17, 2003 8:14 am
OG Lifer
Do what that one guy did. He coated the inside of his cab, (about halfway up) with that tough coat bed liner stuff.
PostPosted: Sat May 17, 2003 8:16 am
i've been thinkin to use that stuff on my frame or something like that.
PostPosted: Sat May 17, 2003 8:19 am
OG Lifer
When I build my flatbed, I am gonna coat it with that stuff.
PostPosted: Sat May 17, 2003 8:21 am
do you think that would add alot of weight to the truck? atleast with that stuff you wouldn't have to worry about rust :D
PostPosted: Sat May 17, 2003 8:24 am
OG Lifer
Its not very heavy. It weighs a little more than the stock bed. I am building my own chassis also.
PostPosted: Sat May 17, 2003 9:22 am
Yeah, I've already got plans to do the Herculiner. That's why I pulled the carpet out. It's all going to come together. :wink:
Kuranosuke
Grampa's Driving:
got BOOBIES? 8O 8)
PostPosted: Sat May 17, 2003 3:24 pm
if i put a 2 in body lift will i have to do n e trimming or can i leave everything the way it is if i do i might design a front lift kit which i have already mentioned before thanx. matt
PostPosted: Sat May 17, 2003 3:56 pm
I can't say for sure as I didn't do this one. The way it looks, however, you will probably have to do some sort of trimming (or shifter bending) to reach the 2nd, 4th, and R positions. Damn, I really would like to go with the coil over setup, but don't have the foggiest idea what to get or how long to get them.
Kuranosuke
Grampa's Driving:
got BOOBIES? 8O 8)
