It is currently Sat Jun 27, 2026 6:45 pm
 Post subject: 4.3 swap
PostPosted: Sun Jul 08, 2007 1:23 pm
i've got an 80 chevy luv that is all stock currently. I have just been given a 92 4.3 that was bored.030 over with 350 flat top pistons and a 700r4. I am in the process of getting the harness and computer to make the tbi work. I was wondering what else needs to be swapped and how diificult the swap is. please contact me if you have done this swap, i need alot of help
PostPosted: Sun Jul 08, 2007 1:51 pm
This will be a good and a easy swap,all you have to do is the same as the V8 swap but you will have a whole lot more room to mount the radiator.Look up the V8 350 swap info and you will have a pretty good idea on what to do and i think the manifolds will fit with no problems to as for headers Downy toyota makes headers to fit toyotas and they may work.
PostPosted: Sun Jul 08, 2007 5:05 pm
how would the 5 speed go in as far as shifter placement. Would any firewall modifications. I have the 700r4 but this is my weekend car so i just cant see having an automatic in it
PostPosted: Sun Jul 08, 2007 5:39 pm
The 5 speed will add to the project , but can be done .
PostPosted: Mon Jul 09, 2007 6:10 am
I have a cable type bell housing that i used in my 78 LUV with a 283 but i don't have a cable for it .It's a Monza bell and i think the cables are available still,then you make the clutch pedal end fit. It's and easy thing to do.
And yes you will have to cut a hole farther back to install the shifter,the rest is the same as you would do with the auto.
Using a T-5 with this swap would be a cool swap and no you don't have to modify the fire wall.
PostPosted: Mon Jul 09, 2007 1:56 pm
do you rhink that i should run a edelbrock dual plane manifold with a performer 500 or stick with the tbi. is there any way of not using the computer for this motor and if so what other parts need replacement
PostPosted: Mon Jul 09, 2007 4:10 pm
kind of depends on what your aiming for
you can find alot of 4.3's out of s-10's and blazers and probably someone who has done it before on some of the s-10 forum sites.
before alot of s-10 owners switch from a 4.3 to an LSx motor they will supercharge it and do alot of other mods. You might find someone selling the stuff on the s-10 sites.
I know someone in TX who keeps offering my a complete 4.3 w/ harness, cpu and transmission. I just dont have the cash nor the room to go after it at the moment.
PostPosted: Tue Jul 10, 2007 5:02 am
Your on the right track with the manifold and carb, then all you have to do is get a dist. and you will have a computer free runner.
You can try to find a used HEI dist. or as i would go to the after market and get one like a MSD,DUII,or Mallory then you would have a permanent set up.
If you are going to get inside the motor use 350 flat top pistons as this will make the motor a stout street performer.
PostPosted: Tue Jul 10, 2007 12:20 pm
I already have the motor. like i said its bored .30 over with 350 flat top pistons and stock injection. I also have a 700r4 but i want to run a five speed out of an s10
PostPosted: Wed Jul 11, 2007 5:03 am
Well then the simple way (cheaper) is to run the t-body injection and is very simple to hook up other than you need a fuel pump and a return line and it is done .Like i said i have a bellhousing if you get a T-5 trans.
I know it may sound like a pain to run the injection but the start up and drive ability all year long would be more than worth the trouble.
Also if you use a S-10 rear with 3.42-3.73 gears you would get excellent fuel milage as well as a stout performer.
PostPosted: Wed Jul 11, 2007 6:40 am
I have a t-5 out of a v-6 camaro i will sell cheap! $100+shipping
72 luv v-8 owned since 16!
240" rear engine dragster
[color=#FF8000]
29 dodge 4 dr sedan (project)
PostPosted: Wed Jul 11, 2007 1:04 pm
how will the 4.3 computer handle the t-5 trans and if you have parts for sale to help me with this swap let me know prices and shipping to 48067. thank you all for the help. I tried to get help from s10 forums but those guys are just complete ideots.
PostPosted: Wed Jul 11, 2007 2:29 pm
The reason you will get help here is the fact many of us have done the conversions and have a ton of success.
PostPosted: Wed Jul 11, 2007 3:12 pm
yea i noticed they asked me what i was doing the swap to, when i told them it was a luv they fought with me for about fifteen minutes that chevy never made a luv until i posted a pic of mine
