It is currently Sun Jun 07, 2026 3:42 pm
 Post subject: smokin
PostPosted: Thu May 08, 2003 8:30 pm
what is normal smoking on a 2.2 diesel 81 if any thanks in advance?
PostPosted: Thu May 08, 2003 9:34 pm
Normally diesel engines smoke at startup (especially when cold) and under heavy load.
 Post subject: white
PostPosted: Tue May 13, 2003 9:56 pm
what would white smoke mean at start up on this diesel. 2.2 81 4x4
PostPosted: Tue May 13, 2003 10:06 pm
OG Lifer
Probably water. Hate to say it but it looks like a head gasket. Do you have oil in your water or vice versa? If your oil is milky and nastier looking than normal, you may have a blown head gasket. Try taking your glow plugs out and pressurizing your radiator with a little shop air. Not too much, I think most radiator caps are 16 psi so you could probably safely use 10 psi. If you hear hissing in one of your cylinders, that is a head gasket. Good luck :wink:
NOTE: The white smoke may only be condensation in your cylinders or tail pipe.
WATCH YOUR PIEHOLE!!!!!!
 Post subject: other way
PostPosted: Tue May 13, 2003 10:29 pm
is there any other way to tell for sure i dont have much to work with? i know my radiator cap is leaking so ill probably have to replace it. my water is ok and my oil does not look bad.
 Post subject: ohh
PostPosted: Tue May 13, 2003 10:31 pm
ohh it only does it in the morning after its been off for a long time. hope its good news
PostPosted: Tue May 13, 2003 10:44 pm
Resident Sparktrician
If you need to do the head gasket, contact the guy from this auction: http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33665&item=2415327875. Great prices, great service, and he probably has what you need. I don't get anything from this. I was just impressed by their operation...
Kuranosuke
Grampa's Driving:
1990 Luv 4X4 "Family Cab"
got BOOBIES? 8O 8)
PostPosted: Tue May 13, 2003 11:32 pm
OG Lifer
*cough KICKBACK cough* :lol:
 Post subject: thanks
PostPosted: Wed May 14, 2003 6:34 pm
thanks might be the best advice ive ever gotten
