It is currently Wed Mar 18, 2026 1:24 pm
 Post subject: SBC turbo anyone?
PostPosted: Sat Jun 23, 2007 12:22 am
anyone done it or know where i can get some GOOD information on it
or know of a good kit
i really wana do it but want to know if it is a good idea
and will a stock SBC handle around 15 pounds of boost
it's a 70's block
On the search for another Luv Machine
PostPosted: Sat Jun 23, 2007 5:06 pm
no a stock sbc will not handle 15 pounds of boost,you might get away with say 3-5 or so,but you need good parts to run that much,good rods,bolts,steel crank,forged low comp pistons,etc
72 luv v-8 owned since 16!
240" rear engine dragster
[color=#FF8000]
29 dodge 4 dr sedan (project)
 Post subject: Re: SBC turbo anyone?
PostPosted: Sun Jun 24, 2007 8:47 am
it's a 70's block
What kind of horsepower are you looking for?
What are your other plans for the motor? rod, pistons, crank, heads, compression? There is alot that goes into a turbo motor, not only for powr, but especially reliability.
Here is a basic rundown of what I would do AT THE BARE MINIMUM :
Factory 4 bolt block - main studs, head studs, checked for flatness of the decks, and no more than a .030 overbore(less is better for strength.
Forged crank- stock stroke or go for a 383.
Good forged rods- H beams preferably. Eagle or Scat are cheap and hold up well.
Forged pistons - you can use TRW etc if you are on a budget, but JE, Wiseco or CP pistons really prefered. You will need to know the heads you plan to use so you can set compression at no more than 9-1.
Use Cometic head gaskets, a decent set of heads and a mild cam, with minimal overlap you should be good to go.
You could do some type of FI or you can get a blowthru carb. Carbs work fine. CSU is the best place to get one for a blowthru setup.
You could do a couple of t3/t4 hybrids and be around 700hp without any difficulty.
You want to do a cheapo setup? Get a pair of t3's off of Tbird turbocoupes, flip a set of shorty headers, get a holley carb gone thru for the blowthru setup and have fun. Will blow up eventually, but 350 shotblocks arent expensive. Should be able to make enough power to get a hooked up Luv into the 10's. :twisted:
PostPosted: Sun Jun 24, 2007 10:12 am
well thanks guys i was just wanting to know pretty much what i needed to do before i hooked a turbo up.
I love the sound of a turbo and if i can get one on my sbc it will be great.
ya i wish i could put it in a luv but my deal fell threw.
So i am looking at getting a El camino or something along those lines
we found a z/28 t-top we might get it might be good for this project
