It is currently Sun Jun 28, 2026 5:44 pm
PostPosted: Wed Jun 06, 2007 6:32 pm
System is not charging an the Alt. was changed by last owner. I dont think it is fully connected as the wiring has a black wire I believe with a loop. I need to see where these connect to I think it is not grounded. Help me out
PostPosted: Mon Jun 11, 2007 7:34 pm
Nobody can help with this problem? I do not know where the black wire connects to. And running hot on warm days any ideas
 Post subject: .
PostPosted: Mon Jun 11, 2007 7:46 pm
This picture should zoom pretty large. Do you need the connections at the other end?
FIAA: Color Guard
PostPosted: Mon Jun 11, 2007 10:44 pm
The thicker wire with the eyelet goes from the post on the alt to the positive terminal on the battery.
The 3 pin plug is somehow involved with the voltage regulator & other stuff. :?
Did I mention I hate electrix?
I went to a 1-wire, internally regulated setup last year to toss the Vreg & clean up the bay some.
_________________________
83 Isuzu I-Mark 1.8
01 Saturn L300 V6
PostPosted: Fri Jun 15, 2007 2:03 am
I seem to have an extra Has eyelet I did notice in the picture of the wiring above. shows 2 wires on the ground. maybe that is it needs 2 connected. Crap I'm lost
PostPosted: Sat Jun 16, 2007 10:38 am
http://s131.photobucket.com/albums/p289/johnboyp1963/
Here some photos of my alternator.
The alternator by itself is oem stock. The one mounted is 80 's isuzu.
The one not mounted if you look. It has a 2 wire pigtail that plugs into the truck wiring harness. On the upper left you will see the letter E thats were the little black grounding wire goes. The upper right has an A letter, Thats were the bigger black wire goes. Its the wire that goes to the battery.
Users browsing this forum: No registered users and 91 guests
