It is currently Mon Jun 08, 2026 6:47 pm
 Post subject: Overheating-Running Bad
PostPosted: Mon Jun 11, 2007 2:06 pm
Trying to see if anyone has any ideas.. I have a new carb on. The truck was running ok and then all the sudden the thing is overheating all the time now. It blows raidiator fluid all over the place even took the thermo out and the thing still runs hot. Someone said that if the carb is out of wack it will cause the engine to overheat. I cant get the carb diled in rght at all.
PostPosted: Mon Jun 11, 2007 3:36 pm
since it's blown liquid all over, have you checked the distributor? when those get wet you usually have to buy a new set of points, or if you're lucky, just clean off the contact points inside the cap. if those get wet ur just basically setting off all the plugs at random, causing it to majorly overheat.
:-p
hopefully that helped
PostPosted: Mon Jun 11, 2007 11:07 pm
mine used to get hot, too hot for comfort, then i put a new radiator and an electric fan... now it stays cool.
(PLATINUM STREET RODS)
Deming, NM
PostPosted: Wed Jun 13, 2007 7:20 pm
These engines are very prone to blown head gaskets. Especially after they've been overheated. Check out the cooling system, and also do a cylinder leak down test.
PostPosted: Thu Aug 09, 2007 10:04 am
I put a radiator from a Jeep Mail Delivery truck in mine and she runs really cool - like I can run 75 MPH and it won't go past normal cool on a 98 degree day.
PostPosted: Thu Aug 09, 2007 10:15 am
It may be pressurizing cooling system with combustion gases from a blown head gasket or a cracked head. This will cause radiator cap to blow out the excess pressure.
