It is currently Sun Jun 28, 2026 3:34 am
 Post subject: Broken Brakes
PostPosted: Sun Jun 10, 2007 8:00 pm
So i bought all new brakes, callipers rotors drums wheel cylinder etc, etc.
Should have only taken one day. Friggen one of the new callipers had a leak. It took bleeding the brakes three times before I realized this was why the pedal kept going to the floor. So I just put the old one back on, works fine.
question:
And I guess since we have two resivoirs, that when you drain only the fronts (rear res.) , you only have to bleed the fronts, correct?
78' LUV Mikado, Old
