It is currently Thu Jun 25, 2026 7:42 pm
PostPosted: Sat May 26, 2007 6:25 pm
What's the best way to move a complete engine? I plan to put it in the back of my truck, but I'm not really sure how to 'mount' it, or what to do to keep it from sliding around. Pick up is planned for this Tuesday, so your ideas before then would be appreciated :)
PostPosted: Sat May 26, 2007 8:09 pm
last one i did i pur a tire no rim in the back and then the motor, oil pan fits in hole good... then strap down... never had a problem doing it that way
PostPosted: Sat May 26, 2007 8:15 pm
The last one I moved just had a block of wood underneath on one side and straps to keep in in place. I moved it about 80 miles that way.
I like the tire idea though. Never thought of that.
PostPosted: Sat May 26, 2007 8:45 pm
The tire is good, a pallet with a slat or two cut out for the oil pan works too.
I just use 4 straps, each pulling out to the four corners of the bed, so it can't move. And drive carefully.
PostPosted: Sat May 26, 2007 8:47 pm
I use the tire method mostly.
PostPosted: Sat May 26, 2007 11:08 pm
PITA Old Fart
Yep...an old tire or two and some straps to cinch it down does the trick.
Only probem is what to do with the old greasy tires when you're done...lol
PostPosted: Sat May 26, 2007 11:16 pm
We use old tires at work to help hold the crane's load ball. That's the large round steel ball with the hook on one end. You don't want it rolling off the trailer onto the 405. 8O
PostPosted: Sat May 26, 2007 11:26 pm
Thanks guys :)
PostPosted: Sun May 27, 2007 9:04 am
rondog isn't that called a head ache ball? :lol:
PostPosted: Sun May 27, 2007 9:15 am
Yes it is. :lol: load block is the big one, and headache ball is the round one.
 Post subject: Moving an engine
PostPosted: Sun May 27, 2007 9:31 am
You could move it piece by piece but it would take awhile. :lol: LOL
'78 1.8L 4-speed Fleetside
Image Image
PostPosted: Tue May 29, 2007 7:38 pm
ron just wanted a reason to state that he has large steel balls :P
but yeah a old tire (something like 31 x 10.50s work reall well) or a couple wooden blocks and some ratchet straps. be sure to stop and check the tension on the straps after a few miles.
PostPosted: Tue May 29, 2007 10:09 pm
well me and nukeday both lifted it into his luv with oil still in it although it didnt have intake or exhaust manifolds on it as well. all in all it can be moved safely with a couple guys.
PostPosted: Tue May 29, 2007 10:18 pm
did you load the flaires also
PostPosted: Tue May 29, 2007 11:17 pm
he will snag em next time he comes down here I have to grind the pop rivet heads on the inner fender. been working 70hrs a week lately 8O
PostPosted: Tue May 29, 2007 11:27 pm
ok thanks, maybe ill make it down one weekend need to go see mom :lol:
PostPosted: Wed May 30, 2007 12:21 am
Well, luvprojects did most of the lifting and shoving. I felt like an old man trying to heft that sucker :roll: . Couple hundred pounds for sure...
Guess I should start a thread on the 4x4 now, but as it is I snagged quite a few parts, not to mention my Weber came in the mail yesterday :)
luvprojects was kind enough to not mention how my truck crapped out on the way down. Took about an hour to sort it out, ignition switch popped something and quit outputting voltage to the + side of the coil, less than 10 miles from Sutherlin. The Oregon Highway Patrol stopped by to check on things, the officer looked about 12 to me, but was really cool and left me alone. Said he'd come back to check later if I was still stranded, he wanted to make sure I had a cell phone or AAA. Jumpered the coil directly to the battery, the other half of the switch still works. It's an aftermarket switch, I'll have to sort it out tomorrow...Anyway, once I had it hotwired, it ran great the whole trip.
So here's the goods:
The Weber came in the mail with the strangest foam stuff in it I've ever seen. It was sort of this crumbly, flaky stuff...Anyway, the ball shaft looks nearly perfect, so it was a good score...
PostPosted: Wed May 30, 2007 8:58 am
there is an old key shop here and he has the luv keys, they say LUV-1 one them and he said he can key the switches if you need... this guy has uncut keys back to model A's
