It is currently Sun May 10, 2026 8:25 pm
 Post subject: Seatbelt parts
PostPosted: Sat May 19, 2007 12:33 pm
Anyone got an extra lower seat belt latch(??), the part that comes up through the seat.
Mine has an issue, makes 3 times now I've litteraly been trapped in the seat because the latch won't release without a fight.
FIAA: Color Guard
 Post subject: Re: Seatbelt parts
PostPosted: Sat May 19, 2007 1:23 pm
Whats the drama??? Just think of how safe you are just sitting there all nice and safely restrained.
:wink: Bob
PostPosted: Sat May 19, 2007 2:14 pm
just a (?) did you drown it in w-d40 mine was like that and i put a lot of it in there after a while it starts to work it is not allways the case what color do you need and year they are not all the same i know my 76 wont work with the 79 ok color/and year the ones i have are tan/gold and out of a 76
dangerous-toys4life
75 k-5 2x
94 king cab
 Post subject: .
PostPosted: Sat May 19, 2007 5:06 pm
budbondo wrote:
just a (?) did you drown it in 4-d40 mine was like that and i put a lot of it in there after a while it starts to work it is not allways the case what color do you need and year they are not all the same i know my 76 wont work with the 79 ok color/and year the ones i have are tan/gold and out of a 76
May try the WD40, for now I just swapped it over to the passeger side. Let the wife fight to get out ;)
Mine are 28 year old faded maroon, probably the worst looking part of my interior. If I ever come up with some buckets, I'll swap out the whole set.
FIAA: Color Guard
PostPosted: Sat May 19, 2007 5:34 pm
The WD-40 should work. Fixed a stubbor one that I had on my '75.
PostPosted: Sun May 20, 2007 3:20 am
The rear seat belts from an '85ish Trooper have the right latch pattern for the stock belt, but are about 4 inches shorter. That's what I've got in the '79 now. Mine were actually broken and missing pieces..
I haven't confirmed it yet, but it also looks like mid 80's S10/S10 Blazers may work. They look about the right length and they even come in a hideous maroon color... :wink:
PostPosted: Sun May 20, 2007 7:38 am
I got a tan set. Driver's side. Send me an e-mail if you want it. It came out of my '78 after I swapped it for a '79. I found out that the seat belts were not the same, so you need the whole set to match the latches. I can photograph it for ya if ya want.
'78 1.8L 4-speed Fleetside
Image Image
PostPosted: Sun May 20, 2007 9:18 am
Yes. I've done the whole "piece together a set of belts" myself, and I don't know what years, but some buckles and some latches do not match and will not work together. Try to get a complete set so you know it will work. BTW, I'm talking factory LUV belts.
