It is currently Tue May 26, 2026 3:27 am
 Post subject: alternator question
PostPosted: Tue May 15, 2007 6:37 pm
ok heres the deal.....limited on space so I went junk yarding to find the smallest alternator possilbe.I found a mitsubishi alternator off a 82 ford courier.I need some help wiring this thing. I'm wondering is it possible to 1 wire it . It has a 4 plug square connector on the back with only 3 wires coming out of it. The plug is marked E N on the top and F A on the bottom E F N are used and a single wire off to the side marked B . Ithink B is the wire i need its white with a red stripe. Any light you can shed on this would be great.
PostPosted: Tue May 15, 2007 9:17 pm
http://fordfuelinjection.com/index.php?p=63
this help?
It has different model numbers...
b should be to charge the battery (pos using heavy cable)
one should be for a warning light and the other should be for pos battery voltage
Did it have a regulator on it? I think it should be internally regulated.
Get the pig tail?
PostPosted: Wed May 16, 2007 1:32 pm
Yes.....that helps alot ,and yes I got the pigtail. Thanks alot man!
