It is currently Tue Feb 03, 2026 1:52 am
Post new topic Reply to topic  [ 40 posts ]  Go to page 1, 2  Next
 Post subject: Project Shrinky-dink
PostPosted: Sun Apr 29, 2007 2:11 pm
Truck Specs:
Chopped 3inches
Channeled 5 inches
narrowed 9", Currie 9+ nodular case w/4.56 gears
32x14 slicks
4' 1" to the top of the roof 8)
Just ordered a bunch-o parts to get this thing rollin! MSD ignition, 3500 stall convertor, reverse man. valve body, hughes performance tranny rebuild kit, and other small misc. parts.
Gonna temporarily run the 327 I built for my old 'camino.
Specs:
Bored .030 over
Balanced
ARP rod bolts
Edelbrock aluminum performer rpm heads
Crane gold series roller rockers
Sig Erson cam
10.5:1 forged pistons
Fluid damper
Yada Yada
Last edited by Whole_lotta_luv on Sat May 19, 2007 12:00 am, edited 2 times in total.
PostPosted: Sun Apr 29, 2007 2:39 pm
It should be fun. So when will be the target test drive date?
PostPosted: Sun Apr 29, 2007 2:46 pm
I'm hoping to have it at the track by June sometime. We'll see how it works out. Depends on how motivated I stay lol.
You have a buildup thread for your truck? That looks like one bad ride! 8)
PostPosted: Sun Apr 29, 2007 7:56 pm
That should be a fun ride.
PostPosted: Thu May 03, 2007 11:54 pm
Torched the floors and firewall out and got a mock up motor/tranny sittin in it. Stuck the motor back so far that the front axle centerline cuts #1 and 2 cylinders in half and still leaves me a 1/4" from the back of the 750dbl pumper to the firewall. Gonna pick up some 20gauge this weekend and start puttin a floor/firewall together :) I still can't get over how short this thing is. 4'1" to the top of the roof 8) Will get some pics when there's something worth taking pics of.
PostPosted: Sat May 05, 2007 9:31 pm
Here's a couple of pics. Nothin special to look at yet. Gonna pick up some sheet metal soon and put a floor and firewall in it. It's scootin along so far
PostPosted: Sun May 06, 2007 8:31 am
You going to run one of the front mount distributor conversions? Coming along nicely.
PostPosted: Sun May 06, 2007 4:38 pm
Where can i find one of these? That would sure make life a whole lot easier. Otherwise I have to get at it from the interior :roll:
PostPosted: Sun May 06, 2007 8:22 pm
MSD makes em for sure. NOT sure what the total cost is. The dist. itself is like $249, but I'd assume you have to run a crank trigger and a dummy shaft to complete it. With the set back you have, it'd sure make the install easier though.
PostPosted: Sun May 06, 2007 9:13 pm
Cut some more out of the bed to clear the tires. Still need to trim a little bit more but you get the idea.
PostPosted: Sun May 06, 2007 9:14 pm
I'll definitely be looking into this. You'd still have to have the shaft to drive the oil pump, but do you have to run coils on every plug with a crank trigger since there would be nothing spinnin the dizzy?
PostPosted: Sun May 06, 2007 9:42 pm
I'm pretty sure a belt turns the dizzy. If I can find a link I'll post it.
PostPosted: Sun May 06, 2007 9:46 pm
Here ya go:
http://www.msdignition.com/pdf/2005/FRM ... 0_8520.pdf
PostPosted: Fri May 11, 2007 5:29 pm
I hate to highjack , I really liked those year fords . Truck is coming along nicely .
PostPosted: Fri May 11, 2007 6:19 pm
It's called a FORD 302. :lol:
(Sorry I used the F word. Please don't ban me. :roll:
PostPosted: Fri May 11, 2007 6:48 pm
It'll be for sale here pretty quick if ya wanna buy it :smt023 It's a pretty fun ride. 78 f150 shortbox, 12 inch lift, 42" swampers, fairly well built 460 and a np435 mated to an np205.
PostPosted: Fri May 11, 2007 6:51 pm
Thought about it, but I all ready have a BUNCH of Chevy parts kickin around. Plust putting a ford in a chevy just wouldn't be right :smt104
PostPosted: Fri May 11, 2007 10:34 pm
You will have space for a nice BIG radiator to keep that thing cool ! 8)
-Austin
PostPosted: Sat May 12, 2007 12:36 pm
Here's a pic of one of the "CHEVY" front mount distributor conversions.
PostPosted: Sun May 13, 2007 7:41 am
Depending on how you build your dog house you should be able to run the stock type dist. al though it will be tight. Also you can get low profile dist.caps and make it work.On my truck i did some checking a figured that a stock small cap dist. wold work as i have a 6" dog house and i would probably put an access door in anyway. I think i have some pic's as i think my motor is setting close to what you have .
