It is currently Mon May 25, 2026 11:17 pm
What thermostat are you running ?
180 Degree 24%  24%  [ 4 ]
160 Degree 53%  53%  [ 9 ]
No Thermostat 12%  12%  [ 2 ]
WTF is a thermostat ? 12%  12%  [ 2 ]
Total votes : 17
 Post subject: Thermostat on V-8 Poll
PostPosted: Tue May 08, 2007 8:11 pm
What thermostat are you running ? Are you running one ? What temperature is it at ? Motor specifics would help !
-Austin
PostPosted: Tue May 08, 2007 8:19 pm
what year is your v8? Which V8? how big is the radiator? alum or copper radiator? How many more or less gallons of coolant from stock?
Normally if its directed towards performance Id go as cool as possible... but if your doing alot of highway mileage and want better mpg then somewhere near the hotter side.... of course you still want a little bit cooler than what your aiming for... just incase
PostPosted: Tue May 08, 2007 8:27 pm
I was just taking a small survey to see what people are mostly runnin. But yeah, I need to get an electric fan on my radiator :)
-A
PostPosted: Wed May 09, 2007 1:55 am
I got a aluminum 19x22 griffin radiator a 160 degree thermostat with a mechanical fan. It stays around 170-180 degrees 80% of the time.
1975 V8 Luv
1980 Bagged Luv
