It is currently Sat Mar 28, 2026 5:20 pm
 Post subject: My trany is going bad
PostPosted: Mon May 07, 2007 9:47 am
My rear bearing is going out , anyone have any ideas on a fix, I looked up on the net to see if I can find one only to find front ones. How about an up grade does 5 speeds fit into a 1.8, Does anyone know where I can find a good trany, I am in Washington state west side So far I have found two Luv's for sale they dont want to part out, one for 250.00 and one for 400.00 both 76's. I also found a 80 but haven't talked to the owner just sittin in the yard.
PostPosted: Mon May 07, 2007 1:18 pm
on the bong
5 speeds will fit. You can find one in izuzu pups, rodieos, and the impulse. If you have an older luv with the hydro cluch go with the impuse.
PostPosted: Mon May 07, 2007 1:37 pm
anybody got a pic of an impulse? i have no idea what they look like...
PostPosted: Mon May 07, 2007 2:01 pm
on the bong
http://images.google.com/images?hl=en&r ... a=N&tab=wi
Try that, If That doesn't work try going to google.com, and go to images, and search for "izuzu impuse"
 Post subject: trany
PostPosted: Mon May 07, 2007 5:11 pm
Can you be more detailed on the years of 5 speeds fit the 1.8 the wrecking yards dont seem to know and I am new to this
 Post subject: trany
PostPosted: Mon May 07, 2007 5:13 pm
Also what are all the motors that interchange to 1.8
Thanks
PostPosted: Tue May 08, 2007 12:51 am
on the bong
any thing prior 88 I beleave, and u will have an easyier time with a 76 or earlyer luv since they are set up for a hydrlic cluch, and 77 and later are cable cluch, also I think it has to be the non turbo model with the g200. also look at izuzu rodeo, or izuzu pup will have a g180 or g200 motor. And 76 and earlyer models are slightly differnt than later models of the engine. hope that helps.
PostPosted: Tue May 08, 2007 1:55 pm
i got an engine and 5 speed you could have if you wanted to come get it, but i'm a little far. inside the tranny looks clean, but the outside is covered in dirt. it's still attatched to the frame, but the body is off it.
 Post subject: trany
PostPosted: Tue May 08, 2007 5:24 pm
Thanks for the offer but your right to far for me to go. Just a matter of time, I will find one here.
Thanks again
