It is currently Sun Jul 13, 2025 1:47 am
 Post subject: stock juice
PostPosted: Thu Aug 22, 2002 9:31 am
O.K.gang...just got an '81 4x4 and want to get some more ponies outta the thing but don't really want to go with a engine swap..(kinda like the original stuff)...This thing climbs like a mountain goat but lacks a wee bit on the power when asked for..help me out here..I was so jazzed to find a site dedicated to the LUV as I used to own a '76 that was alot of fun and sure do like the style...Got the 4x4 for the son but he strayed on me and went with a Bronco...(A ford?? YIKES!!!) anyway, help me with some stock power...Don't need to run in the 12's but do need to be on top of the hill next to the big boyz...lay it on me !!!!!
PostPosted: Sun Aug 25, 2002 11:09 am
I think the first question should be, is passing smog a concern?
If at first you don't succeed, try it like your wife told you to do it.
 Post subject: hey
PostPosted: Sun Aug 25, 2002 7:43 pm
hey i jsut changed the oil in mine today and im still runnin the stock ponies. i put a can of restore in with the mobil 10w-30 and i started the little power plant up and took off- it helped out on the horsepower for sure - and im sure it did something with the compression cause ive never got up to 55 so quickly in that thing as i did today. but if your climing hills and stuff with yours i dont what she'll do.
Brent
PostPosted: Tue Aug 27, 2002 8:57 pm
dont ouote me on this but ive heard the webber carbs help the ponies on a stock eng
heres one on ebay
http://cgi.ebay.com/ebaymotors/ws/eBayI ... :B:SS:US:1
also look at running a high flow air filter (like k&N) i know accel makes a universal one that will fit
and maybe a high flow cat w/ like a magnaflow muffler
hope this helps ya
PostPosted: Thu Aug 29, 2002 4:11 am
Hey cheetua,
I also have an 81 4x4 and know just how you feel ,well I did, go to J.C. Whitney and check out exaust they sell a header from pace setter bolts right up and make a night and day difference in power! If smogging the vehicle is a concern then try running some good quality plugs and get all the ignition parts cleaned up real good or replaced and run some good sythetic oil. and check into the weber carbs on the market mine works great. and if you can get away with no smog then tear it all off and get the header. Hope this helps Im sure I'll think of something later...
Dave
PostPosted: Mon Sep 02, 2002 2:30 am
There was a few people around here selling intakes and stuff for stock motors awhile back. The search button is your friend. :)
